Longtail cargo bike project
agniusm   100 MW
Post by agniusm » Jun 29 2013 12:13pm
Yet another frame. This time going amberwolf style. Went to a scrap yard, picked up 7 chinese, russian bike frames, few old steel bed ends, 65kg of steel. This is my catch:
Today i felt inspiration and went to my workshop to do some chopping chop-shop style. Here is what i came up with:
The system i am thinking about:
500/1000W 6t MAC motor on 20" 80mm wide rim with 3" tyre
Front - 24" 56mm rim with 2.5" tyre
12FET infineon - 40A
20AH <10C 16S lifepo4 with built in BMS
3A DC converter
6A onboard charger
Single speed chain drive
Still need to finish bottom cage for stiffen the bike and electronics components for stealth;
Make 10mm dropouts and weld them on;
Order woven wooden basket;
Look for short cranks(dont know if thats what they called) for pedals as there is little space from the pedals to the cargo cage;
Figure brakes
I think this bike would be able to carry family of three, two adults and a child or some cargo. I have another cargo bike coming slowly but remote steering is a job and half to get it right, in the mean time this is simple, nice side project. Anyway, when i am done with these, i will have 4 fully custom bikes on my account:)
If you have any suggestions, get them down
Cheerios
P.S. This the second time i am posting in wrong thread for some reason, probably need to have less windows opened.
MODS, please move it to technical section for me. Sorry for inconvenience.
dogman dan   100 GW
Re: Longtail cargo bike project
Post by dogman dan » Jun 29 2013 5:50pm
Done. Looks cool, love seeing what you are up to.
No doubt you aren't finished, but it looks to me like it's weak vertically, right behind the front seatpost. Needs some gussets or diagonals to haul lots of weight on that platform.
agniusm   100 MW
Post by agniusm » Jun 29 2013 6:05pm
dogman wrote:Done. Looks cool, love seeing what you are up to.
Sure it does. Ran out of bed ends and time, good enough for 5 hour work I think :) Waiting for monday when scrap yard will open
agniusm   100 MW
Post by agniusm » Jun 30 2013 7:52am
Had overnight thought and will rebuild rear fork from larger tube.
I was wandering if anyone knows what largest tire will allow MAC motor clearance for belt drive system?
At the moment the thinking is to use 80mm rim with 4 1/4" tyre
Also what shortest cranks available for reasonable money?
agniusm   100 MW
Post by agniusm » Jul 02 2013 9:44am
Got my 4th torque arms made:
They are massive, 12mm thick
Revised rear end as it was looking weak:
docnjoj   100 GW
Post by docnjoj » Jul 02 2013 1:50pm
You should consider selling those torque arms. They are the first I have seen that you could get with the pinch bolts.
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
dogman dan   100 GW
Post by dogman dan » Jul 03 2013 7:14am
OOO! I'm liking that a lot now!
agniusm   100 MW
Post by agniusm » Jul 11 2013 3:30pm
Revision to the front end:
agniusm   100 MW
Post by agniusm » Sep 21 2013 3:26am
Hi. Question: i will need to guide the chain under the back frame as there will be a battery and all electronics box in there. Can i use jockey wheels for that purpose:
It says it has sealed bearings, 7075Al?
agniusm   100 MW
Post by agniusm » Sep 30 2013 7:46am
Parts are coming in slow but stady:
agniusm   100 MW
Post by agniusm » Nov 20 2013 2:55pm
Few more parts arrievd:Image
agniusm   100 MW
Post by agniusm » Nov 29 2013 5:09pm
Could someone suggest a stem riser/extender? It would be good to get 180-200mm rise. Semi integrated headset bearings, 1-1/8 inch.
Thanks
dogman dan   100 GW
Post by dogman dan » Nov 30 2013 8:01am
You need the bars higher? I just found it easiest to use a bmx handlebar, that has the rise built into it. Like in the earlier pix.
A long fork steer tube will allow lots of spacers though, if you don't cut the tube shorter. Looks like you have some length there now.
I don't know of any threadless handlebar stems that have much rise in them. If that fork is threaded, then the stems for comfort bikes are the tallest I have seen. Hunt one on ebay I suppose.
agniusm   100 MW
Post by agniusm » Nov 30 2013 8:29am
The only one i found that will do is SATORI EASY UP STEM RISER. I wander if they are reliable and worth a try.
EDIT:
OK, bit the bullet and ordered it along with 70mm 10degree Token stem. Will see how all mates together.
Now thinking on the other hand easy up stem sounds good if there is more people using one bike. QR type adjustment of stem height is a good thing.
agniusm   100 MW
Post by agniusm » May 10 2018 6:51am
Reviving this one. 20S battery, BT bms, and kls7030s. Made a box for all the stuff. Will have marine plywood deck and aluminium box:
docnjoj   100 GW
Post by docnjoj » May 12 2018 6:52am
I see that you still have the skillz! What kind of batteries are those?
otherDoc
agniusm   100 MW
Post by agniusm » May 17 2018 1:57am
Hi mate. Was away for long time but i am back :). Those are the batteries which is the reason i was away and two kids i made :) They are no solder/weld modules i developed for 18650 cells and inside LG 2500mah 6P (www.18650.lt)
Its hard to forget hard learned skilzzz :D
Got the deck made. Was sketching up aluminium body of the cargo box. Not as easy to make it fold with minimal weld lines but i am there. Just need to print template and get weldin bendin.
docnjoj   100 GW
Post by docnjoj » May 18 2018 5:31am
That is a quality template! Are you saying that your weld free battery holder is not available?
otherDoc
agniusm   100 MW
Post by agniusm » May 19 2018 9:49am
OH, it is available for basically a year now :) 2P through to 8P
docnjoj   100 GW
Post by docnjoj » May 21 2018 7:26am
Are these modules and kits actually ready for sale. They look brilliant!
otherDoc
agniusm   100 MW
Post by agniusm » May 21 2018 8:49am
Yes, you can buy them right now since last July. Go to www.18650.lt
agniusm   100 MW
Post by agniusm » May 22 2018 1:27am
So i went the hard way with aluminium. Just forced myself and threw a foldable chassis in sketchup. Designed with minimal welds but still there is some. Had to force myself in advancing of welding aluminium. Turned out alright.
Have set up my BT BMS and all worked from the first time, nothing blew :)
agniusm   100 MW
Post by agniusm » May 22 2019 3:15am
Revived my project as family needs transportation for summer, going to lakes etc.
This has removable box deck so i can mount what i want. Had no time to finish cadilac style big one so made smaller one just for time being. It runs vented x5303 with kls-7230s.
I have a lot of parts 3d printed. Its a fantastic toll every bike builder must have. Battery is made eith my NESE kit, 20S7P, VTC6 24AH.
I have tested it and it polls mad. 2 things i need to address. 1. Flex in the frame. Being that long does not help. I will triangulate from the deck to the head tube. 2. Motor axle clamps. Made them too big and they dont clamp well. Photos:
3d printed tail light
docnjoj   100 GW
Post by docnjoj » May 23 2019 10:52am
Wonderful quality work, as usual!
otherDoc
999zip999   100 GW
Post by 999zip999 » May 23 2019 2:46pm
Looks more user friendly then the Cadillac rear end. Metal skills.
