19" Motorcycle Wheels vs 26" Bicycle Wheels (rim and tires)
Cricket_Swe   100 W
Re: 19" Motorcycle Wheels vs 26" Bicycle Wheels (rim and tir
Post by Cricket_Swe » Jun 07 2017 11:52pm
Great thread! Thanks for the info, it was very helpful to me
Torti   10 mW
Post by Torti » Jun 10 2017 3:34pm
Hello, I have SM Pro rims 19 x 1,4 and a Mxus xf40, can someone tell me which spokes I need.
markz   100 GW
Post by markz » Jun 10 2017 10:37pm
Use the spoke calculator at www.ebikes.ca and perhaps they might even have that motor in their list of motors, if not then you punch in the correct numbers yourself.
You will need the ERD of the rim, hopefully its printed on the rim, or you can find the specs online for that rim.
The motor measurements are easy to do as well, and is well documented at ebikes.ca
Torti   10 mW
Post by Torti » Jun 11 2017 2:03am
Super thank you ever.
Motor is in the list Mxus xf40-45H, the rim is not.
Rim is a MX SM Pro 19x1,4
I have the rim unfortunately not yet!
markz   100 GW
Post by markz » Jun 11 2017 2:00pm
Where are you gunna buy your proper length spokes?
Torti   10 mW
Post by Torti » Jun 12 2017 12:11pm
I do not know what length.
markz   100 GW
Post by markz » Jun 12 2017 3:22pm
OK so you want super strength and durability - You need butted spokes so its stronger at the flange then the spoke thins out. It seems logical to go thicker spoke but thats not the reality of it. The spoke needs to flex from my gatherings, so thats why its thinner at the nipple side, but you need strength at the curved part of the spoke that goes to the flange so it needs to be thicker guage.
Ianhill   1 MW
Post by Ianhill » Jun 12 2017 3:41pm
Iam in bit of a pickle myself I need to get a spoke set made to fit the mxus 3k turbo into a 20" Alex rims dx32 rim, I've seen it done on a2beast's metro with 10 gauge spoke to the stock rim so its not impossible, the only problem is the spoke angle is 65° anything over 70° puts stress on the nipples with a stock bike rim, I need a 1 cross pattern with 10gauge at the hub flange and 13gauge at the rim only custom spokes will work but its going to be at a very steep angle for a the stock rim so it's safer to use a 1.60 ×16" moped rim with angled holes to suit a 1 cross spoke design then use 10awg straight through and that will make the ride more harsh but the wheel can go much greater speeds.
Mammalian04   100 kW
Post by Mammalian04 » Jun 12 2017 4:14pm
Bucahanan for Custom Spokes.
Also, Holmes Hobbies has some standardized sizes. I usually go for their wheel spoke combo but you might have to order custom from Buchanan (or some other place) for your wheel.
markz   100 GW
Post by markz » Jun 14 2017 9:18pm
I am trying to lace a rim with 68 deg nipple angle, I got the spoke length for 2x. Plus my nipple over hang is only 0.82mm. Its basically a no go.
Oh well my good rim comes tomorrow, and hopefully my spokes as well, for a proper 1X on a proper rim.
Was kinda wanting to ride tomorrow thats why I tried lacing it tonight on an old rim, and some spokes I had laying around. But that was just a regular mtb rim. The moto rims are looking better and better because the nipples seat in the angle.
Torti   10 mW
Post by Torti » Jun 28 2017 1:42am
Hello,
I am looking for a hub 110/20 for 3 mm spokes?
Rix   100 GW
Post by Rix » Jun 28 2017 9:06am
Torti wrote:Hello,
This hub is rated for 12-10 g spokes. http://www.eastgem.net/hub.html
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Jun 28 2017 12:57pm
Ianhill wrote:Iam in bit of a pickle myself I need to get a spoke set made to fit the mxus 3k turbo into a 20" Alex rims dx32 rim, I've seen it done on a2beast's metro with 10 gauge spoke to the stock rim so its not impossible, the only problem is the spoke angle is 65° anything over 70° puts stress on the nipples with a stock bike rim, I need a 1 cross pattern with 10gauge at the hub flange and 13gauge at the rim only custom spokes will work but its going to be at a very steep angle for a the stock rim so it's safer to use a 1.60 ×16" moped rim with angled holes to suit a 1 cross spoke design then use 10awg straight through and that will make the ride more harsh but the wheel can go much greater speeds.
Redrill the motor hub for paired holes? http://www.ebikes.ca/tools/spoke-calc.h ... ng-options
Using different spacings will allow for different angles and maintain the cross pattern you want.
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
agedashidofu   1 W
1 W
Post by agedashidofu » Aug 13 2017 10:43pm
Hi folks,
Was wondering if anyone can help (apologies in advance if this question has been answered)
I currently have a QS205/50H V3 motor set up on a 19" X 1.6" rim. Does anyone have any recommendations on which "road tire" will fit? Will be mainly using this to commute, so looking for a good road tire that will fit.
I've currently stumbled on a Dunlop D401 90/90-19 (width between 2.75 - 3.00) which has great reviews - but says recommended rim is 2.15.
The other one I found was a Pirelli MT66 90/90-10 (width between 2.75 - 3.00) - but also says recommended rim is 2.15
Do you think they will fit into the 19X1.6 rims?
I can't for the life of me, find any "road tires" that will fit on these rims (can only find offroad tires)
Many thanks in advance for your help!
Rix   100 GW
Post by Rix » Aug 13 2017 10:54pm
agedashidofu wrote:Hi folks,
Those tires will fit your rim, however, a 90/90 tire is going to be closer to 3.75 inches wide. Thats a big tire. You would really be better off going with a Shinko SR244 2.75-19 tire which is about a 60% road 40% dirt tire for motorcycles, but for ebikes, it can be a 100% road tire with no problems.
DasDouble   100 kW
Post by DasDouble » Aug 15 2017 10:08am
Have just tried to put a 80/90-21 wheel on my 24" rim.... This does not fit... Bullsh*t! :|
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
Chalo   100 GW
Post by Chalo » Aug 15 2017 12:58pm
DasDouble wrote:Have just tried to put a 80/90-21 wheel on my 24" rim.... This does not fit... Bullsh*t! :|
By "wheel" and "rim", do you mean tire and rim? Or do you mean wheel and frame?
Whichever you mean, a 24" bicycle rim measures 20" at the bead seat. So hypothetically, it would fit a 20" moto tire (though spooning it on might damage the rim).
DasDouble   100 kW
Post by DasDouble » Aug 15 2017 1:43pm
I meant a 21" moto tire on a 24" bicycle. Now I will go with the 70/100-19 F546. Looks quite neat and seems like it will fit on my 24" mtb rim.
http://www.shinkoreifen.de/motorrad/rei ... cross.html
-Built own ebike: ✔
Rix   100 GW
Post by Rix » Aug 15 2017 6:43pm
It wont fit on a 24MTB rim, the bead will blow off the rim as soon as you exceed 5 PSI. Traditionally 24MTB rims are 20" OD, your typical adult size dirt bike rim is 21"x1.60 wide.
markz   100 GW
Post by markz » Aug 16 2017 12:17am
17" moto rim fits 20" bicycle
19" moto rim fits 24" bicycle
21" moto rim fits 26" bicycle - Assumed
https://www.electricbike.com/moped-rims ... hubmotors/
I have a 16" x 1.60 steel rim bought it for $50cdn, found a few others recently in the online classifieds, thought about purchasing them, but no need really. HolmesHobby has his last batch of 17x1.60 rims that come to $125cad shipped to Canada. Its a little steep price wise for my liking. I dont mind heavier steel, rusty bits for $50cad. I will lave the 16" x 1.60 into my MXUS 3000W thats still apart, laziness on my part. Get by with my Conhismotor 1500W that I have up for sale locally. I am in no rush to sell it, but perhaps I should be as winters coming and would like cash to buy mid-drive then dont have to worry about rims and spokes and breakage.
What will my 16x1.60 be converted to bicycle wise, I'd guess 18" maybe 18.5" bicycle. Which is perfect for my needs. For the Direct Drive setup, smaller diameter wheel = slower speeds, but my MXUS 3kW is 4T, no worries there. Then I prefer lots of torque for my fat lazy ass, and smaller diameter = shit tons of torque. Please dont confuse a lower Turn Count motor to have more or less of anything compared to a higher Turn Count, just the propogated Myth that Justin talks about here.
http://www.ebikes.ca/learn/hub-motors.html
One false and oft-repeated conclusion is that therefore the 409 is a higher torque motor than the 406 because it can produce the same torque with fewer amps, or likewise more torque with the same amps. This is not the case. All 400 series motors can deliver exactly the same torque at exactly the same efficiency. The lower winding count motors just need more current to do this, but because they have fewer turns of a shorter length of heavier gauge wire, they can handle high currents with minimal loss. To use a concrete example, lets compare a 404 with a 408. The 408 has twice the number of turns than the 404, so the copper wire in the windings has 1/2 the cross sectional area and twice the length, for a total of 4 times the winding resistance of the 404. For a given torque output, the 408 needs only 1/2 the amps, but because it has 4 times the resistance the net electrical loss (I2R) is exactly the same.
Another consequence of having a larger number of turns around each stator is that the voltage induced in the winding by the passing magnets is increased in direct proportion to the number of turns. So for instance, at a certain speed of rotation, the 408 motor will produce twice the back-emf voltage as a 404 motor rotating at the same RPM. To power a motor, the battery pack voltage needs to be greater than the back-emf voltage, and so the 408 motor needs twice the voltage to spin at the same speed as a 404. However, it will only draw 1/2 the current, and you can see that the net power input (Volts * Amps) remains the same.
Also there is a thread here on ES about the Myth, its long, but it mostly makes sense to me now.
https://endless-sphere.com/forums/viewt ... hilit=Myth
Its long. Just read what Justin says, much clearer.
DasDouble   100 kW
Post by DasDouble » Aug 16 2017 4:49am
Oh boy, now Im f*cking confused as hell... Holy cow.. :roll:
It wont fit on a 24MTB rim, (?)the bead will blow off the rim as soon as you exceed 5 PSI. Traditionally 24MTB rims are 20" OD, your typical adult size dirt bike rim is 21"x1.60 wide.
Jimboyr6 wrote:Hi im running 1.4 19" moto rim works great with 2.75 x19 trail tyre best thing i ever done
A 19 is the closest match to the mtb 24" wheel.
Looks great!
Where did you buy your tire and tubes? Trying to source some over here...
Got a michelin 70/100/19 tube,and the 2(.)75x19 trail tyre of ebay or u can get 3.00x19 tyre.
<<ENTER BIG CONFUSED EMOJE HERE>>
-Built own ebike: ✔
DasDouble   100 kW
Post by DasDouble » Aug 16 2017 4:59am
I have tried a 21" moto tire before and it is way to big to fit on my 24" bicycle rim. Now order is already made.. Lets have a look what a 19" moto tire looks like on a 24" bicycle rim... :roll:
-Built own ebike: ✔
skeetab5780   10 MW
Post by skeetab5780 » Aug 16 2017 7:11am
I know this is a 19" wheel thread but if anyone wants a steal of a lifetime here is the link below
There is a lot of 17" steel VOLOCI wheel sets(front/rear) on EBay for a great price of $100 a set free shipping! This is not my sale, just spreading the word!
http://www.ebay.com/itm/Set-of-Voloci-e ... 1438.l2649
This rear wheel used the same famous 135mm dual disc hub used by me and many other ES members, with beast thru axle included! It is worth it alone to buy the set for the rear hub. The front wheel is a QR so you will likely have to re lace it to a 20mm thru axle but it is simple an I've done it easily with no experience.
Note these wheels are bomb proof and are steel! They add a decent amount of weight to the build but can handle 20kw no problem
brumbrum   100 kW
Post by brumbrum » Aug 16 2017 7:17am
Trying to fit a motorbike tyre on a bicycle wheel is ridiculous. Its not going to happen, and will lead to disaster. Would you really feel confidnt going 50mph on an ill fitting tyre and rim combination?
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
DasDouble   100 kW
Post by DasDouble » Aug 16 2017 7:55am
brumbrum wrote:Trying to fit a motorbike tyre on a bicycle wheel is ridiculous. Its not going to happen, and will lead to disaster. Would you really feel confidnt going 50mph on an ill fitting tyre and rim combination?
What about this dude? He has done that. Also motorcyle tires last way longer then bicycle tires. I have tried the 24x3 one from LMX I think it was and its now already done, down to 1mm while my rear motorcycle wheel still looks like it has 80% of its rubber left. And I never brake with front break by the way.. :roll: :pancake:
GCinDC wrote:Going to include links to other member's 19" MC wheel builds. Feel free to add more. Here are a couple now:
ZombieSS's Official Greyborg Warp build thread
Electric Jeepster - New(ish)member new build
-Built own ebike: ✔
