wrobinson0413
wrobinson0413 said:Thanks Rick for the info. Sounds pretty straight forward to hook up. I wonder how accurate the Cycle analyst can be using the raw current sense like that. I have had experience with some high performance servo controllers that use resistive shunts, and their current sense is fairly sensitive to the length of the differential pair coming off the shunts. The amount of noise that can be coupled into the lines gets larger the further away you get away from the shunts, especially with the bridge running. I suppose I will just have to try it out.
Cheers
Wayne
wrobinson0413 said:Since I have not taken apart any ebike controllers recently, maybe you can tell me if they are placing the shunts behind the caps, ie. between the mosfet source pins and the negative side of the caps, or whether they are placed after between the negative lead and capacitor/source pins. I realize that this is a little off topic, but it would help me understand what portions of the current that the Cycle Analyst actually it looking at when hooked up to a controller instead of the standard method with the external shunt looking at battery current.
Thanks
Wayne
wrobinson0413 said:Hi Justin
Just a couple of more questions regarding the current sense. So with the digital controllers, they are using the standard brushless DC bridge configuration with sense resistors.
From your description of the pulse by pulse current limiting, I would gather that these controllers are not close loop current controlled, but rather controlled by peak current limiting .
Is this being used to give feed back on the motor current only or is it being used to infer the battery current.
But, maybe I am not understanding the function of the Cycle Analyst. Is it not just a monitoring system to datalog and display battery stats, with a shutdown feature for when the battery is discharged
wrobinson0413 said:One other detail that you might know is what sort of switching scheme is being used by the BLDC ebike controllers. Are they using complementary magnitude with center aligned or edge aligned PWM?
By the way, did you start you trip off ok? I hope that you have your rain gear, because Ontario has been seeing record rain falls. Maybe we will have some dryer weather for you when you pass through(^^).
This is what I thought most ebike controllers did for their switching scheme. I do wonder though if the new regen controllers like golden motor's use a more advanced method? Maybe you know, Justin, since you seem very knowledgeable both about ebike controllers and PWM technical stuff.justin_le said:wrobinson0413 said:One other detail that you might know is what sort of switching scheme is being used by the BLDC ebike controllers. Are they using complementary magnitude with center aligned or edge aligned PWM?
Neither generally. The techniques you are referring to apply when you have all three (or at least 2) phases doing PWM, as required for sinusoidal drive waveforms. While there are sinusoidal BLDC setups, pretty much every single ebike controller uses a trapezoidal drive, where one phase is held tied to a bus, another phase does PWM, and the 3rd phase is in a high impedance state.
Justin
This is what I thought most ebike controllers did for their switching scheme. I do wonder though if the new regen controllers like golden motor's use a more advanced method? Maybe you know, Justin, since you seem very knowledgeable both about ebike controllers and PWM technical stuff.justin_le said:Neither generally. The techniques you are referring to apply when you have all three (or at least 2) phases doing PWM, as required for sinusoidal drive waveforms. While there are sinusoidal BLDC setups, pretty much every single ebike controller uses a trapezoidal drive, where one phase is held tied to a bus, another phase does PWM, and the 3rd phase is in a high impedance state.
BTW, what does your own new bike controller use for it's switching scheme, Justin? I'm sure it must be something better than the standard ebike controllers, specially if you pack so much power into such a small box! Maybe it uses the more advanced scheme Wayne suggested, using offset complementary switching of the phases or some such thing?
BTW, good luck on your trip, Justin - You are an inspiration to me for sure! Techs that travel off the beaten path are not too common (non-existant?) where I live! I hope to cross your path when you hit the east coast...
Patrick
Johnbear said:Does anyone know the specifications of the resettable polyfuse for the + connector to the cycle analyst?
Thanks!
