Recommendations for battery and phase wire plug/socket?
kiwipete   100 mW
Post by kiwipete » Jan 10 2014 8:07pm
I have a little 6 FET controller (25A) and am looking to tidy up the wiring because with the current multitude of plugs and leads it resembles a big bowl of spaghetti. :-(
So I'm going to take it out of its current housing and install it into an aluminium diecast box with 3 sockets mounted onto the sides of the box:
- a DB25 socket which handles all the signal/control wiring, so thats under control.
- a socket (and matching plug) for the battery wires.
- a socket (with matching plug) for the 3 phase wire for the motor.
Any recommendations for the socket and plug combos?
izeman   10 GW
Re: Recommendations for battery and phase wire plug/socket?
Post by izeman » Jan 11 2014 2:14pm
for battery connection i use andersons 45a types and for phase wires i use 5.5mm goldies.
they can handle 5kw peak and not melt :)
EDIT: sorry. you were asking for mountable sockets. no idea for that :(
Caliban   100 mW
Post by Caliban » Jan 11 2014 5:14pm
I did once consider using a DB13W3 to integrate high current and signal lines. The power pins can be rated at 40A so it is feasible but I'm not sure I would really recommend it.
alsmith   100 kW
Post by alsmith » Jan 18 2014 8:14pm
You can chassis mount powerpoles of different ratings.eg 45A should be enough for your phase and battery connections, but you can go higher.
atom1025   100 W
Post by atom1025 » Jan 19 2014 2:52pm
Bashed Synergy Cycle runs
1800w peak, 31mph tops.
2004 Cannondale Jekyll with a MAC 10
15s 8ah lipo (2100w peak) 31mph tops.
