Please help to ID this motor
Thriller   1 W
1 W
Post by Thriller » Apr 13 2014 8:49am
I bought this motor in a kit not knowing much about it. It is a 48V 1000W motor. I bought a 7 speed cassette to fit it and then took a measurement and it is about 152-153mm wide, way wider than the standard 135mm. The axles have 12mm flats on them. It also seems odd that the spokes are not crossed? I will upload pics from my phone right away.
Thriller   1 W
1 W
Re: Please help to ID this motor
Post by Thriller » Apr 13 2014 8:58am
Thriller   1 W
1 W
Post by Thriller » Apr 13 2014 9:06am
If I went to a single speed on the back, does it attach the same way with a screw on? I have already ordered 4 x 6s 5000mah lipo batts from hobby king and yes I am aware of the risks with them as I use them on RC as well. By the time I machine the axle to fit a 10mm drop out and have to go with a single speed is it better to go with a different inexpensive wheel or complete kit?
dogman dan   100 GW
Post by dogman dan » Apr 13 2014 4:27pm
The axle dimensions sound like the kind found on the big motors. But the kit you bought might have only a 1000w controller.
The radial spokes clearly suck.
What's best for you, depends on what you want to do. Don't cut that axle if you want to run big wattage.
TMaster   1 kW
Post by TMaster » Apr 13 2014 5:57pm
I agree, you need to have a crossed spoke pattern. I wouldn't even run it like that. I would re spoke the whole rim. sigh, its a time consuming process.
The motor looks like a clone of all the others, 9C, yescom, golden motor, etc... All 1000W. They can handle a lot.
Specialized HR - 75 lb's
A123 26650M1 23S4P(75.9V Nominal) 7500W Peak
Infineon Lyen 12 Fet/45amp controller heavily modded pushing 110 Amps peak
Yescom Motor with upgraged phase wires (Golden Motor/9C replica)
Thriller   1 W
1 W
Post by Thriller » Apr 13 2014 6:59pm
So does the single speed gear for the wheel go on the same way as the cassette does? Just screw on? Would I have to buy new spokes since these would be to short?
kentlim26   10 kW
Post by kentlim26 » Apr 13 2014 8:46pm
even some huge 3000w hub motor is dropout is 149mm. my fren had bought from vpower the dropout is too wide too.
Conhis hub motor run on April 2010, 48v 1000watts hub motor distance run 5800km, and Re~alive cyclone kit bought in year 2009, Bought a greentime controller 18fets- 4110 , 48v~ 90v , 3-speed mode. Latest top speed I got for my greentime controller 76.8km/h ! , yet to reach 80km/h, or I will never reached 80km/h ?
TMaster   1 kW
Post by TMaster » Apr 13 2014 10:54pm
You will need all new spokes. I have my motor centered with the rim and only a 5 speed cassette will fit. I have 2 tube spacers made from some stainless steel that fill the space to 135mm. I also machined spacers to space the disc brake out to line up with the caliper. Not sure how the 7 speed fits, but I'm guessing the motor wont be centered with the rim.
dogman dan   100 GW
Post by dogman dan » Apr 14 2014 8:17am
It does sound to me like the wider magnet motors rather than the 28mm 9c type.
To really find out, you might have to open er up, and measure the magnet width. If its the high power motor, again, I would NOT cut that axle smaller.
Respoke it, if not now you will have to later.
If it's 28mm magnets, then filing down the axle will be fine. Screw on freewheel, but I think there is a different size screw for bmx. So make sure it's the right threaded hole size when you buy a ss. A good bike shop will have it fairly cheap.
Ypedal   100 GW
Post by Ypedal » Apr 14 2014 8:33am
http://ypedal.com/Redhornet.htm
Like like that one.
Radial is not the way to go with larger rims but since it's already built.. i'd run it until it finally does break apart.
as dogman said, i would not mess with the axle diameter, strap an 18fet lyen on that puppy at 60+ amps and enjoy the ride !. :twisted:
ES site status page:
Thriller   1 W
1 W
Post by Thriller » Apr 14 2014 3:51pm
Ok here is what it is. Magnets are 39.11mm wide
Magnet width
Thriller   1 W
1 W
Post by Thriller » Apr 14 2014 3:54pm
Here are the windings.
Thriller   1 W
1 W
Post by Thriller » Apr 14 2014 3:56pm
Side note- why do some of my pics have to be downloaded to see and others do not? I am using the upload attachment button for all of them.
Thriller   1 W
1 W
Post by Thriller » Apr 16 2014 8:43pm
Does anybody have an idea or seen something like this before? :?:
Ypedal   100 GW
Post by Ypedal » Apr 17 2014 7:21am
file size is the reason for the pictures showing up as clickies vs directly... shrink them down and they will just display.
Thriller   1 W
1 W
Post by Thriller » May 06 2014 7:31pm
anyone with any idea's yet? :?
wesnewell   100 GW
Post by wesnewell » May 07 2014 12:40am
Where did you buy it. Looks like a much more powerful motor than typical 1000W motors.
cwah   10 GW
Post by cwah » May 07 2014 1:06am
Only 39mm magnet. Not a torquy motor?
Thriller   1 W
1 W
Post by Thriller » May 07 2014 7:48am
I thought that 39mm was wider than normal. But I do not know much. :?
wesnewell   100 GW
Post by wesnewell » May 07 2014 9:46am
39mm is a lot wider than normal for a 1000W motor. And standard ebike motors have 10mm flats.
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » May 07 2014 10:29am
For me it would depend on the type of loads you are putting on this wheel before recommending an immediate relace. I do have to admit that I don't like radial laced wheels, but if the flange is wide enough and you won't be putting huge amounts of side loads on the wheel (hard cornering with heaving loads), I wouldn't worry too much as crosses just add lateral strength, not radial.
Plan on relacing the wheel, but I don't think it's a showstopper.
You've got a real power capable motor there, I would get a bike with 150mm dropouts and put some fat torque plates on it. But then again, I would try to ride that thing at 50mph+.
What speeds you trying to accomplish?
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
