hello es members! i need some help finalising the parts for my build, i was looking at the tc80 kit from ebikes.ca but there 72v controller only does 40amps max, i was thinking about running this then upgrading the controller to an adaptto at a later date when funds permit, can those infinion controllers be modified?, i know lyen sells controllers on here and im not quite sure the difference, they are both infinion based controllers, the ebikes controllers seem to have nicer wiring connectors and state they are not programmable, whilst the lyen controllers seem to be rated at higher amperage and are programmable.
would it be wise for me to get a tc80 kit from ebikes.ca or just grab the motor from them and a controller from lyen to get me up and running for the mean time until i get the adaptto, i want the smallest controller possible but obviously that doesn't go hand in hand with high power output.
the reason i was looking at the crown is due to the fact i can squeeze a cassette onto the crown and make it fit whereas the cromotor would require a single speed and im not sure if i want to go down that route especially due to the single front chain ring on the bike (giant glory 1) , but i am scared the crown will be crap compared to the cromotor and they weight basicly the same , there is alot of positive feedback on the cromotor and not much info on the crown especially at higher voltages where some seem to have found issues with them.
battery setup will be 72v 2x Turnigy nano-tech A-SPEC 5000mah 10S 65~130C in a camelbak, i may run another pair unconnected as a reserve. any ideas would be greatly appreciated, i am trying to build more of a trail weapon that will keep up with my mates stealth bomber than a commuter , something very similar to this, which gave me some good ideas http://endless-sphere.com/forums/viewtopic.php?f=31&t=48207&start=75#p831410
but i want something with a little bit more gusto than a 3kw setup. i will use drbass torque arms if i can attain a set or i will have some machined up locally, regarding milage i would be happy with anything over 10miles on flat ground but am open to ideas on extending range whilst keeping weight as low as possible,
any ideas would be much appreciated! thanks
