Adaptto BMS Battery Pack Connections / Configurations
crea2k   10 kW
Post by crea2k » Jun 26 2014 4:22am
Thought id set this up, so people can post circuit diagrams of the various different battery pack setups, and how they are wired up into the Adaptto BMS. Il start with this one, which is a 12 x 6s lipo pack setup. Im guessing that its correct now, after taking bits from various diagrams, but give me a shout if its not, and I will change it and re post it up, as I don't want anyone blowing anything up.
crea2k   10 kW
Re: Adaptto BMS Battery Pack Connections / Configurations
Post by crea2k » Jun 26 2014 4:25am
This is the original PNG file, if anyone else want to make their own pack configs.
kudos   10 kW
Post by kudos » Jun 26 2014 6:51am
It looks a bit awkward wiring up 6S packs to the 4S bms boards eh!
Might be an idea to use 4S packs maybe.
Kudos
Build 1A Gary Fisher Wahoo Hardtail : Crystalyte HS3540 40A 49V : 31mph
Build 1B Gary Fisher Wahoo Hardtail : Mac 10T 30A 49V : 27mph
Build 1C Gary Fisher Wahoo Hardtail : Crystalyte HS3540 40A 82V :
Build 2 Mountain Cycle Fury FS : Mac 8T 40A 57V : Scrapped
Build 3 GT LTS FS : Mac 10T 30A 49V
Build 4 EEB : Mac 8T 40A - In Progress
crea2k   10 kW
Post by crea2k » Jun 26 2014 7:15am
Problem is it only allows 28s before you have to start hacking about, id get through that in no time at all off roading.
upek   10 W
Post by upek » Jun 26 2014 7:25am
Definitely correct!
crea2k   10 kW
Post by crea2k » Jun 26 2014 7:59am
Thanks !, I will try building it once my balancing cables arrive :)
Tench   100 kW
Post by Tench » Jun 26 2014 8:34am
I have a load of 4s and 6s cables with female plugs on if you have not already ordered some?
I have looked at your diagram and also think you have it correctly wired, go for it!
Project one http://endless-sphere.com/forums/viewto ... ilit=tench
Project Two http://endless-sphere.com/forums/viewto ... =6&t=37489
The uk's first Stealth Bomber
There is a box inside your head, inside amongst others are the words "Wont fit" stop looking for answers in the box, there are no answers only excuses.
crea2k   10 kW
Post by crea2k » Jun 26 2014 8:46am
Thanks !, iv got my cables on order already though, so just waiting for them to arrive :) , my hot air rework station and soldering station dont seem to belt out enough head (I use them for circuit board stuff), so have ordered a cheapo heavy duty soldering iron to do the job.
crea2k   10 kW
Post by crea2k » Jun 27 2014 6:19am
I know that usually the BMS manages this, but because I am rigging this up in a non stadard way, I really want to be checking all the packs are balanced first the first few times im thinking ?.
Iv been looking at this, would this do the job, or can I get one that will do 4 at once ?.
http://www.hobbyking.co.uk/hobbyking/st ... duct=43590
zlagger   10 W
Post by zlagger » Jun 30 2014 5:05pm
What program did you use to make this diagram? Looks great!
crea2k wrote: Image
crea2k   10 kW
Post by crea2k » Jun 30 2014 5:51pm
Thanks :) , it was drawn with adobe fireworks
Mammalian04   100 kW
Post by Mammalian04 » Jul 03 2014 7:46pm
Anyone have a good link to a site that can educate me on BMS wiring. I am at a loss on what and why you are wiring the way you do.
Brake   100 W
Post by Brake » Oct 19 2014 1:36am
Hey guys,
So I am trying to connect the BMS finally. But, for some reason I cannot wrap my head around these diagrams.
Hoping you could give some advise.
Do I need to attach wires as shown here in black joining the boards together? And also after looking at different drawings it gets confusing as to what exactly is positive (+). On the board itself it shows a + and - printed on the boards. Some drawings are showing the board from the back and then look like the + red wires go to the negative terminal on the boards.
I have a 22s pack with a balance wire installed around each cell bank. This is driving me crazy. Maybe I do a drawing.
Thanks. Brake
Brake   100 W
Post by Brake » Oct 19 2014 1:41am
Crea2k, is it as simple as that your 4s balance plugs have to get flipped around before you plug them into the boards?
crea2k   10 kW
Post by crea2k » Oct 19 2014 3:47am
Not sure what you mean as they will only plug in one way ?.
Brake   100 W
Post by Brake » Oct 19 2014 11:19am
Thanks for answering. I think I'm getting too analytical with this. I'm wiring up everything from scratch. But to keep it simple, a store bought 4s pack simply plugs in correctly? Polarity wise I mean.
Brake   100 W
Post by Brake » Oct 20 2014 12:40am
I figured it out and why i was confused.
In Crea2k's drawing the balancing plugs are all wired up correctly. The red wires going into the 4s balance plugs are (+) voltage. However, these plugs gets turned around 180 degrees before they are inserted into the BMS ports. The BMS board ports are labeled with + and - and are exactly how you want the voltage polarity lined up. In the earlier drawing I posted, the black lines that are drawn across board ports are necessary. If you had a stock battery that was 4s, these connections are already done.
My battery is a straight 22s 10p 18650 and so I had to add these board connections.
Cheers, Brake.
crea2k   10 kW
Post by crea2k » Oct 20 2014 5:24am
Ah I see what you mean now, mine was just adapted from one of the Russian forum diagrams which didn't go as far as the socket, only to the plug, but they only plug in one way anyway :-) . I'm currently running it in the config as shown on my diagram, but in a few weeks I'm going to add 3 more packs, one to each pack group so I get more range as I had to turn off the low voltage cut off coming back yesterday as I was 2 miles short, so repaying it today by re balancing all the packs out of the bike. Don't want to be doing that again !.
ridethelightning   1 MW
Post by ridethelightning » Jan 16 2015 5:20am
anyone come across any 'no-no's' re. hooking up the bms?
its just that the way my pack is, i can only hook up the ballence leads to the bms while its not attached to the controller, before installing the pack on the bike and then plugging in the bms leads
is there any trouble with disconnecting the bms while plugging in the ballence boards?
this would be contrary to Jekas instruction, to turn the bms on first, then plug in the boards to the battery.
crea2k   10 kW
Post by crea2k » Jan 16 2015 5:45am
If its balancing and you unplug it from the controller it seems to continue balancing from what iv seen with mine, the lights still flash, so it seems to draw some power from the batteries, is bizarre. I think as long as you dont go shorting stuff out like I did with mine originally it should be fine. Have you not got a circuit breaker inline with your battery packs ?.
Post by ridethelightning » Jan 16 2015 7:03am
no, no circut breaker as such. im confident iv got the wiring right(2nd time iv done this) but just wanted to make sure the board wouldnt do anything odd if i connected it to the cells without the controller...
thanks.
rtl
zooz   10 W
Post by zooz » Jun 12 2016 5:25am
Hi All,
I just built a temporary 13s14p li-ion pack for my new ebike. I have an Adaptto MAX-E with BMS. After reading online, looks like Adaptto BMS only supports an even number of parallel groups, as in 12s, 14s, 20s, etc. I am planning on building a much more powerful pack later on, but right now I have my 13s14p to play with.
Please tell me that there is a way to connect 13s to the BMS?
brumbrum   100 kW
Post by brumbrum » Jun 12 2016 5:46pm
zooz wrote:Hi All,
You must always have at least 2 cells in series for each bms board. So for 13s you would not be able to do..4,4,4,1. You would have to do it 4,3,3,3 or in another way where there are at least two cells together on one board.
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
zooz   10 W
Post by zooz » Jun 13 2016 6:02am
brumbrum wrote: You must always have at least 2 cells in series for each bms board. So for 13s you would not be able to do..4,4,4,1. You would have to do it 4,3,3,3 or in another way where there are at least two cells together on one board.
Thanks for the info. I actually found a diagram made by Adaptto people which explains how to wire up 13s to Adaptto BMS.
Mammalian04   100 kW
Post by Mammalian04 » Jun 13 2016 8:16am
Zoos, I don't need it but maybe post that diagram or the link here or edit your post with so others looking can find it.
