Adaptto Mini-E/Max-E Owner's Thread
aaronski   1 kW
Re: Adaptto Mini-E/Max-E Owner's Thread
Post by aaronski » Nov 30 2015 3:27am
Artur is helping me via PM. looks like red/green are power, but I accidentally hit the chassis. as you said, keep them isolated, as it's just a loop to provide power to the brains of the unit. I'll follow up once I get things more figured out.
Wow I've been here 7 years! had a kid and took a break. Back on a Vector Ebike just for fun.
Broken bike and electric bits everywhere. Sometimes it's a bike and I ride it.
Broken too much crap. pulled 3kw from a 350 watt ebike kit motor, pulled 100c out of HK lipo. much melted wire and plastic. Amazed at the progress this group has made in ebiking.
dafex   1 mW
Post by dafex » Dec 03 2015 3:21pm
Hi all,
I hope someone can answer my question.
My Controller are burned out and i need a new one.
Can i drive with the Adaptto backwards? I mean just to push a switch and it goes backwards. In the Manual i couldn't find anything. I need it for a Trike.
DasDouble   100 kW
Post by DasDouble » Dec 03 2015 3:34pm
dafex wrote:Hi all,
Hmmmmmmmmm that´s interesting.. I have never heared of a controller which can do this.. But this princip of the throttle would be interesting for braking just with the throttle instead of having to brake by dragging the brake with your fingers. Like pushing the throttle backwards or something... :roll: :pancake:
Mechatronics-Engineering Student
-Built own ebike: ✔
-Built own 3.2kWh LiIon battery (300Amps): ✔
-Overtake Porsche with own Ebike: ✔
-Take off with ebike: ✖
~14kW, 3.2kWh LiIon, QS 205 8ml ff, hubsink
Artur   100 kW
Post by Artur » Dec 03 2015 4:49pm
DasDouble wrote:
dafex wrote:Hi all,
This thing exist for a long time already :))
And yes, you can go backward with adaptto. just upgrade to a latest software version and then pres down from Home meny and you can turn on "backward" mode.
dafex   1 mW
Post by dafex » Dec 03 2015 6:12pm
Guess you miss understand me. I did'nt mean to operate the Motor in reverse Mode. I need a function to drive my Trike forward and backwards. Its very inconvenient to go through the Menu to select the "reverse shift"
Or do we mean both the same?
madin88   1 GW
1 GW
Post by madin88 » Dec 04 2015 4:05am
DasDouble wrote: Hmmmmmmmmm that´s interesting.. I have never heared of a controller which can do this.. But this princip of the throttle would be interesting for braking just with the throttle instead of having to brake by dragging the brake with your fingers. Like pushing the throttle backwards or something... :roll: :pancake:
Adaptto has a function called "active mode". If you have this enabled and you apply the brake, the controller first will brake normally like regen does, but below a certain speed (about 6-10kmh on DD bikes) it will push current into the motor the reverse direction which makes it possible to slow the vehicle down to 0kmh. I don't have it enabled because i do not want to "waste" battery for braking, but it's a very nice feature!
I don't know what happens if we change the direction from + to - or the other way round, and apply throttle.
the motor should spin backwards, yes, but i'm not sure if the timing and angle settings need to be adjusted.
Maybe pwrtiming2 or anglecorr2 is for that..
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
Artur   100 kW
Post by Artur » Dec 04 2015 6:28am
It's very easy to turn reverce mode on in 2 sec. First, press down to fast meny, then choose backward. That's all you need :)
DasDouble   100 kW
Post by DasDouble » Dec 04 2015 7:50am
Artur wrote:
DasDouble wrote:
dafex wrote:Hi all,
Do you know a throttle which has this funktion? Normal throttles can go from like 0 - 10 for example (0=no power for motor, 10=full throttle full power). But I need one with something before this "0" thing. Like "minus 10" if you know what I mean. Like an integrated regen-funktion. Just without button, more with "backwards-spinn". Hope you can help me :)
-Built own ebike: ✔
r3volved   100 kW
Post by r3volved » Dec 04 2015 8:56am
There are a few threads on the subject https://endless-sphere.com/forums/viewt ... =3&t=39983
Amberwolf posts some good ES search links in that thread
amberwolf wrote:Some searches for info here on ES that might be useful for this thread:
Topics specifically about this:
http://www.endless-sphere.com/forums/se ... mit=Search
Threads mentioning it:
DasDouble   100 kW
Post by DasDouble » Dec 04 2015 10:19am
OMG THIS IS EXACTLY WHAT I WAS LOOKING FOR :shock: :shock: :shock: :!: :o :!: Thank you really much!! Gonna buy you a bear when you are in my region in germany :D
-Cheers
-Built own ebike: ✔
dafex   1 mW
Post by dafex » Dec 04 2015 10:27am
Artur wrote:It's very easy to turn reverce mode on in 2 sec. First, press down to fast meny, then choose backward. That's all you need :)
Now i found it in the Manual. It is called Quick Menu. That makes life easier. Thanks for help.
You got PM.
DasDouble   100 kW
Post by DasDouble » Dec 04 2015 10:34am
Is a Vectrix throttle compatible with an adaptto controller? Or any other throttle which supports this:
-Built own ebike: ✔
DasDouble   100 kW
Post by DasDouble » Dec 04 2015 3:58pm
He is the Vectrix Throttle ready to order:
http://shop.vectrixparts.com/throttle-h ... -grip.html
Do you think it is possible to use this throttle with Adappto?
-Built own ebike: ✔
drew12345   10 kW
Post by drew12345 » Dec 04 2015 7:40pm
Is there a quick way to adjust the OVS setting? I find myself switching it often. I saw something about quick menu. Not sure if that would resolve it.
drew12345   10 kW
Post by drew12345 » Dec 05 2015 11:47am
I tested the backward function. That can be very helpful. I got stuck in small ditch other day. This feature would helped me in that situation.
I looked at quick setup menu for OVS. No setting for that.
DasDouble   100 kW
Post by DasDouble » Dec 05 2015 6:11pm
drew12345 wrote:I tested the backward function. That can be very helpful. I got stuck in small ditch other day. This feature would helped me in that situation.
If you mean with OVS overspeed or something like that then you have to contact Adaptto via E-Mail. You will loose your warranty if you install this setup but you can. Adaptto will send it to you :)
-Built own ebike: ✔
Mammalian04   100 kW
Post by Mammalian04 » Dec 05 2015 8:38pm
OVS is enabled in the stock firmware in the advanced menu. Not sure why one would need this in the quick menu. If you are worried about max speed, just limit in the profiles.
drew12345   10 kW
Post by drew12345 » Dec 05 2015 10:49pm
I mean to switch quickly between OVS 0 or 7 as an example. During a ride I may switch a few times to conserve battery. It's a pain to go several levels deep to change it. Not sure if highly requested feature. If easy to add, why not.
Instead of quick menu, a better option maybe part of the profiles.
Cowardlyduck   100 MW
Post by Cowardlyduck » Dec 06 2015 3:53am
drew12345 wrote:I mean to switch quickly between OVS 0 or 7 as an example. During a ride I may switch a few times to conserve battery. It's a pain to go several levels deep to change it. Not sure if highly requested feature. If easy to add, why not.
I would also like this as a feature...although so far for me only OVS 1 and 2 seem to give any extra speed, while OVS 3-7 just make the motor heat up faster.
Cheers
My stuff:
Cowardlyducks - Videos - Ride videos
For Sale:
Custom made 18650/21700 battery packs - Australia only
Jackrabbit   100 W
Post by Jackrabbit » Dec 06 2015 4:26am
It is my understanding that the OVS effect only happens once you have reached maximum speed for you motor. Therefore you can leave it on and it won't make any difference to your power consumption until you reach higher speeds.
Cowardlyduck   100 MW
Post by Cowardlyduck » Dec 06 2015 4:50am
Jackrabbit wrote:It is my understanding that the OVS effect only happens once you have reached maximum speed for you motor. Therefore you can leave it on and it won't make any difference to your power consumption until you reach higher speeds.
I think it might do something more than just that.
If I run auto-detect with OVS set the controller set's drastically different values to when I run auto-detect with no OVS set. Specifically with higher OVS levels set autodetect results in much higher (into the negative) hall angle corr, and Ind Timing settings. Without OVS set these values are closer to 0 when autodetect is run.
Cheers
My stuff:
For Sale:
Allex   1 GW
1 GW
Post by Allex » Dec 06 2015 5:58am
OVS engages at about 70-80% of your top speed
Seven   1 W
Post by Seven » Dec 06 2015 4:25pm
I've also noticed ovs drastically changes the autodetect values and believe it will change the behaviour of the motor from 0 rpm
macribs   1.21 GW
1.21 GW
Post by macribs » Dec 06 2015 4:49pm
Cheers
I might be ignorant or plain slow, but once auto-detect is set for me it seems one should not need to mess around with that anymore. For me it seems that once it is first set and the motor runs flawless without stutter why bother changing that at all? Even if you make changes from standard mode to OVS. My understanding of OVS was that that JR say turn it on at forget about it. Timing should be perfect, right? And I must say that part is what I found much appealing too. When bike is done, motor is modified and everything is adjusted and tuned I would prefer to keep riding more then spending too much time fiddeling with the controller settings.
Btw is there any ways to tap data from the Adaptto? I would like to log everything that shows in the display, and run the data on a raspberry PI. To get some fun facts and stats - is there a way to tap into those data?
ridethelightning   1 MW
Post by ridethelightning » Dec 06 2015 5:36pm
Seven wrote:I've also noticed ovs drastically changes the autodetect values and believe it will change the behaviour of the motor from 0 rpm
+1
the difference between ovs 3 and 5 is very noticeable with regards to performance/pickup.
it really feels like my bike has grown a tail at ~ovs 5, and is very responsive at low speeds when negotiating traffic etc.
at lower ovs it feels much more tame at takeoff
