John in CR said:
Marty,
You've got a problem. You're mixing apples and oranges. It appears that you purchased a 5kohm pot throttle, but need a hall sensor type throttle. Worst case there is a hack to adapt, but instead try to get hold of the company you purchased from before they ship, so you can change your order.
John
Test Magura throttle as follows:
Set up DC to DC converter to give me 5V. Multimeter reads 4.96V
Connect 5V+ to Blue Wire = Throttle High
Connect 5V- to Black Wire = Throttle Low
Set Multimeter to 20 volt scale
Red wire to Brown Wire = Wiper
Black wire to Black Wire = Throttle Low
See 0V to 4.95V when I twist throttle.
____________________________________________________________
Test Crystalyte throttle as follows:
Connect 5V+ to RED = 5V
Connect 5V- to YELLOW = Ground
Red wire to Brown Wire = GREEN = Throttle
Black wire to Black Wire = YELLOW = Ground
See .88V to 4.27V when I twist throttle.
Hook up both throttles for test. [Bike is on repair stand.]
Both throttles work pretty much the same. Magura starts out slower. Only possible problem seems to be when I squeeze brake and apply throttle at same time. Wheel will stop spinning, more so with Magura. Don't know if this will be a real problem with bike in actual operation? Anyone have any experience using Magura throttle with Crystalyte 36V 20A Start Immediate Brushless Controller?
