Known to Work Brushless Motor/Controller Wiring Diagrams
shorza   1 kW
Re: Known to Work Brushless Motor/Controller Wiring Diagrams
Post by shorza » Dec 29 2010 5:50am
Cheers.
As far as i can tell, there are 3 combinations that work and all the others either go backwards, run rough or don't go at all. Those 3 combinations that work are all the same as far as performance goes.
Unless someone can correct me.
amberwolf   100 GW
Post by amberwolf » Jan 12 2011 2:01am
A Fusin geared hubmotor on a Lyen 6FET; forward-rotating combination I found (phases and halls are the same):
Fusin  Lyen
B       G
G       Y
Y       B
Wiring BB YY GG will work, too, but it runs backwards. If you have the version with no freewheel, this is fine, but if you have the freewheel version it won't move the bike. ;)
damonjackson_spl   100 W
Post by damonjackson_spl » Feb 09 2011 4:03am
Does anyone have a trusty configuration for ecitypower cute128 48v to ecitypower 12 MOSFET controller??
Liteville Ambassador Australia
Evil Bikes dealer
Custom pinion & Ebikes frames
GrayKard   10 kW
Post by GrayKard » Feb 10 2011 12:00am
damonjackson_spl wrote:Does anyone have a trusty configuration for ecitypower cute128 48v to ecitypower 12 MOSFET controller??
Do the ecitypower controllers still have the programming loop? It's two white wires coming out of the controller that can plug together.
If so, hook up the phase and hall wires matching the colors, then plug the white loop together. Next hook up power to the controller and the motor should spin forward slowly. If it does then power down the system and unplug the white loop and you should be set.
If it spins backward or you can hear the motor turning internally with no movement then you power it back down. Once powered back up it should spin forward slowly, if it does then power the controller down again and unplug the white loop. Should be good to go.
If they don't have the programming loop anymore then no idea sorry. :(
pdf   10 kW
9c controller to 9c motor(?)
Post by pdf » Mar 09 2011 5:27pm
I have a 9c controller, 36v, 27 amps, and a 9c motor. Both have male plugs (??) for what I assume are the hall sensors, black, blue, green, yellow, red. The connector is a 5 pin linear arrangement. There are also two identical connectors coming from the controller with two female three pin terminals but only two are connected to wires; the wires on both are black and yellow. There are also a black wire and white wire, each with its own one pin connector, one female, one male, that are plugged into each other. My questions are:
1) If I am correct about the hall terminals, does anyone know of a female-female sex-swapping jumper to switch one of the male to female? The controller came with an extension, but it is male on one end and female on the other
Otherwise, I have to find this exact connector and cut and remake one female or cut off both and use a 5 pin connector I can get locally.
2) Does anyone know what the other connections are for, that is the two two-pins with black and yellow leads or the black and white connected together? The controller label says: "Function: Automatic cruise, E-ABS, Energy feedback, Mute" I'm guessing the two two-pins are for the e-ABS. Not sure what the black, white connected pair are for.
Jamis Commuter 1.0/Xtracycle Stokemonkey 36V LiFePO4, 15 ahr
Giant Boulder 9C 8x8, 48v, 10 Ahr LiMn from ebikes.ca
999zip999   100 GW
Post by 999zip999 » Mar 25 2011 12:27am
Having problems with a Lyen 12fet. and a bmc 600h.s. checked lot's of combo's all over this site. Disconect the white regen. and ? Much noise. Help. Thanks..
999zip999   100 GW
Post by 999zip999 » Mar 25 2011 1:44pm
Does any one have a wiring diagram for a Lyen 12fet and a bmc 600h.s. I disconnected the white regen. and tried many comb's follow Lyen's page. I hear spinng inside one time next time some growling. Do I take this as a plus. Help. Thanks
Kiwi   1 kW
Post by Kiwi » Apr 24 2011 10:44pm
Xlyte controller to NC Motor
For Forward Direction
Halls
Controller/Motor
red /red
black/black
yellow/yellow
green/green
blue/blue
Phase
Controller/Motor
Blue/Yellow
Green/Blue
Yellow/Green
For reverse direction
Halls
Controller/Motor
red /red
black/black
yellow/yellow
green/blue
blue/green
Phase
Controller/Motor
Blue/Green
Green/Blue
Yellow/Yellow
joystix2   100 W
Post by joystix2 » May 25 2011 10:06pm
All, Looking for wiring connections for a Cute-12 from BMS battery and a Clyte CT4825 from Electricrider.com. Thanks
Ric
Ebikes:
1) DiamondBack Ascent Full Suspension
Clyte Phoenix 5303, Clyte 36-72v 35amp controller, 56v 9ah Milwaukee Lithium Setup,
Orig. Drainbrain, Cruise Control - Top Speed (41mph)
2) Downtube 8FS Full Suspension
Clyte 405 20" wheel, Clyte 24-48v 20amp peddle first controller,
56v 9ah Milwaukee Lithium Setup - Top Speed - 31/32mph
3) Micargi Bronco 3.0 Stretch Beach Cruiser
1000wt Front MAC motor. 52V12.5Ah Lipo pack. 20ah Controller
joystix2   100 W
Post by joystix2 » Jun 16 2011 11:28pm
Got my Cute-12 1000wt motor and Crystalyte 4825 working.
PHASE WIRES:
Controller :arrow: motor
Green :arrow: Blue
Blue :arrow: Yellow
Yellow :arrow: Green
Halls:
Green :arrow: Green
Blue :arrow: Blue
Yellow :arrow: Yellow
Ebikes:
andreym   100 W
Post by andreym » Jun 22 2011 7:17am
Lyen 12 fet ====>>>>> BMC V2S
halls:
Yellow -----> Blue
Blue -----> Yellow
Green ---> Green
phase:
Yellow -----> Blue
Blue -----> Yellow
Green ---> Green
Avanti D8 CroMo frame, CroMotor :) + MAX-E controller. 18s10p zippy compact in Pelican 1300 case. 1.8kwhrs total usable capacity. - Deseased.
New bike will be posted soon here.
fast 1.2kw charger old GT iDrive e-bike
scriewy   100 W
Post by scriewy » Jul 12 2011 1:57am
i wonder, if we open the motor and see the order of sensors, then open the controller and see the order in what holes the signal cables are soldered to, can we know by that what signal cables to connect with motor cables ?
or can we know on the board by where phase wires soldered which 1 is firing first ? (without minding the color)
i mean like if on the board in the first firing phase (lets say most left from top view side with big caps) we got yellow cable, so we know it's the cable connected to first set of coils, the cable in controller can be other color but since we know it's in first firing bank of FETs we connect it to corresponding phase in motor.
or many boards have different set of FETs firing first, like it can be the middle phase or most right ?
it's a pitty i wont stay to see the world crumble, u jedi Scum
clyte 405,
went through battle, bloody resurected Dewalts 4x28v 2s2p usable 2.7ah, 52v drops to 44v at 54kmh
78v 2ah Vdrop to 58v at max 66kmh.
72kg rider + 23kg bike.
keywin 20a 30-70v mod to 6 4110 as methods advised for noobs, shunted 38a
clyte 24-72v 40a mod 4310 to 4110, shunted to 77a
17.5.11 - 5000km
at 78v 4ah 72.7kmh Vdrop to 68v
10.11 - 82.1kmh
30.8.12-17000km
a place for lasers as ES is for e-vehicles - laserpointerforums.com
teklektik   10 GW
Post by teklektik » Oct 18 2011 12:13pm
Crystalyte Analog 12 MOSFET 24-72v 35A controller --> BMC V2 motor
(should work for V1, V3 as well)
phase:
1)  Y --> Y
2)  G --> G
3)  B --> B
Hall sensors (mini-XLR or JST pin numbers):
1)     Red --> Red
2)     Blk --> Blk
3)       Y --> B
4) (Brn) G --> Y
5)       B --> G
Works Fwd/Rev for controller Fwd/Rev key setting respectively.
shock   1 kW
Post by shock » Nov 27 2011 12:30am
Curious if anyone has done a Lyen 6 FET controller wired to an ebikekit geared hub?
This is the combo I have and thought I would ask before the trial and error method.
Thanks , Joe
High Voltage
Jamzz   100 mW
Post by Jamzz » Dec 03 2011 9:50pm
flash_eric wrote:Well, I'm answering my own post. I went through the testing procedure in the thread "How to determine the wiring for a brushless motor" and after figuring out how to avoid damaging the motor/controller, I set upon going through the 36 combinations of Hall/Phase wires. Luck struck on the 12th combination:
Hall
Amped Motor - ECrazyman 48V/30a Brushless Controller
Yel - Yel
Gr - Blue
Blue - Gr
Phase
Yel - Yel
Gr - Blue
Blue - Gr
Works with my 12 Fet Lyen controller and Amped DD 500 watt motor as well.
At full throttle under no load the motor is drawing .7 amps.
Now to hard wire it back up and hit the road. It's been 2 months since I fried a mosfet in the Amped controller. I'm hoping the new ecrazyman will do better.
Eric
shock   1 kW
Post by shock » Dec 09 2011 9:22am
LYEN 6 FET > EBIKEKIT GEARED HUB
Phase:
Yellow > Yellow
Green > Blue
Blue > Green
Halls:
Yellow > Yellow
Green > Blue
Blue > Green
Black > Black
Red > Brown
And here is the throttle connection:
LYEN 6 FET > EBIKEKIT HALF TWIST THROTTLE
Green > White
Red > Red
Black > Black
High Voltage
Kiwi   1 kW
Infineon Controller (e-bikes) to Ezee motor
Post by Kiwi » Jan 11 2012 5:44pm
Infineon Controller to Ezee motor
Phase wires colour match (no change)
Halls
Motor Blue to Controller Green
Motor Green to Controller Yellow
Motor Yellow to Controller Blue
thewmatusmoloki   10 kW
Post by thewmatusmoloki » Jan 13 2012 9:47pm
Lyen 18 fet infineon to Golden motor ...
Phase
Yellow > yellow
Green > blue
Blue > green
Halls
Yellow > green
Green > blue
Blue > yellow
999zip999   100 GW
Post by 999zip999 » Jan 21 2012 5:39pm
Triing to get a 12 fet lyen controller from 7-11, to work with my 9c 2810 motor. Or I could use my 24-72 analog crstalyte controller. Hopefully one good wire combo. Plus a bmc throttle with switch center wires ( right ) Thanks
Edit; controller went south.
electr0n   1 kW
Post by electr0n » Mar 03 2012 9:50am
Crystalyte HS3540 with 72v 40 amp Infineon controller from ebikes.ca:
If your motor wires match this diagram:
http://electricwheels.de/electrical%20w ... otors.html
and controller wires match this:
http://www.ebikes.ca/store/photos/C7240-NC.jpg
Phase wires are colour matched
Hall wires should be:
Motor -> Controller
Yellow -> Blue
Green -> Yellow
Blue -> Green
(Power wires match red to red, black to black)
Thanks to JohnInCR and Fetcher for their posts explaining how to get the correct combinations. Knowing that there are no "incorrect" phase wire combinations just forward or reverse made things much easier. Just a matter of finding the correct hall combination that works with any given set of phase combinations. It only took me three tries swapping hall wires around to get the sequence working right.
atipene   1 mW
Post by atipene » Jun 06 2012 3:21am
48v 500W Bafang geared brushless hub motor to 48v MOSFET controller
Hall Wires
Motor = > Controller
B B
G G
Y Y
Phase wires
B G
G Y
Y B
Bedubya   1 µW
Post by Bedubya » Jun 29 2012 7:51pm
I purchased an E-BikeKit.com front hub geared motor and controller kit Nov 2011... it was great until I blew the controller and throttle... I purchased Lyen 12 Fet controller and had trouble getting the phase and hall cross wiring to work out. I came here and found the various wiring combo suggestions, including Edwads, but none of them worked for me. I got very lucky when I came across the combo that worked for me because it wasn't a combo I would have logically put together. Here's how it went...
Phase:
Controller - Motor
Yellow - Blue
Green - Green
Blue - Yellow
Hall:
Controller - Motor
Yellow - Blue
Green - Yellow
Blue - Green
Throttle:
Controller - Throttle
Black - Black or Yellow (Tip [+])
Red - Red or Brown (Ring [-])
Green - White or Green(Sleeve [Sig])
roxproductions   1 µW
Post by roxproductions » Aug 05 2012 9:39am
I'm having trouble finding the correct phase connections from an Infineon 18FET to a Crystalyte 5404. Anyone got any tips?
40 km/h outrunner kick-bike
35 km/h outrunner longboard
60 km/h FS downhill x5404 20s2p
40 km/h mountainbike 50v MagicPie2 ext controller FS
Bison_69   100 W
Post by Bison_69 » Aug 12 2012 6:42pm
Hi Guys,
I am still surprise that no one has talked yet about the new Crystalyte sensorless hub-motor (HT) which have no dam wire identification... there are only those 3 stupid black Anderson PP45 connectors which give me no clue at all on how to plug it on my brand new 12 Fets controller (124110SL-MII Lyen Edition)
I have tried all combination possible swapping the Y-G-B wires from the controller to the hub-motor and no success... nothing works... there is only the CA lighting on. I used my multimeter and the 48Vdc is present at the power input of the controller but I have no clue how to check the phase power output!...
Thanks for your help....
CityTrackPro 2015 eBike http://http://kobois.com
QS MOTOR 205 H50 V3 hub-motor
KELLY 7230S 90V 120A (300A peak) Controller w/Bluetooth
Large screen CycleAnalyst
Batteries 18650 VTC4 LiFePO4 21S10P
SMART BMS 16-32S / 200A w/Bluetooth and LCD Display
SolidWorks Designer - electric Trike and new eBike frame for a Montreal friend well known on the forum.
Free Personal 3D Drawings download http://grabcad.com/sg/projects
"Your tiny little human brains. How do you get around in those things?"
Hyena   100 GW
Post by Hyena » Aug 14 2012 10:12pm
Is your controller sensorless ?
You need a sensorless controller to go with a sensorless motor (but not the other way around - a sensorless controller will run a sensored or sensorless motor)
Sensorless controllers are easy, usually they either run straight away or run backwards (in which case you just switch 2 wires)
www.HyenaElectricBikes.com
