Larseren
Hi,
Can someone help me while my Adaptto Mini-e is back in Russia? (I never got it to run the motor with sensors so I tried sensorless and think I burned a FET)
I have another controller from this thread http://endless-sphere.com/forums/viewtopic.php?f=30&t=60139. that I will try to use while the mini-e is back for repair.
Batteries are configured 20s 3p (HK hard case Lipo), wheel is 16 inch (motor was in a 26" original)
It has been modified with 4110 FET`s and I have beefed up the traces and wires, soldered some copper wire to the shunt about halfway(it is around 30A stock).
When I try to run the bike it takes off smoothly but when I turn the throttle to rapid it makes this strange sound, I think I am hitting some kind of limit or something.
I find this a little strange since I have replaced the FET`s and reduced the shunt resistance to about half the value ( I have upped the voltage since I ran it stock in 26" wheel from 16s to 20s)
The only way I can measure phase current is with a clamping Amp meter and that has only been tried with wheel in free air to see if it was to much current draw.
You can watch the video to hear the sound. The tire rubs a little so you will also hear that in the video (I have to shave it a little)
[youtube]AwGeO3-lBJY[/youtube]
Lars
Lars
