48V BMS 30A continuous 60A peak
Nobuo   10 kW
Post by Nobuo » Nov 26 2014 5:31am
I've bought this BMS, (30A continuous, 60A peak).
http://www.aliexpress.com/item/13-lithi ... 21963.html
its the only one I could afford..
and I realise that my controler is 45A max continuous.
http://www.aliexpress.com/store/product ... 94528.html
I'm going to make a 48V 13s14p battery pack. that should be able to give 60A max continuous (at ~2C dischargue per cell).
How this could affect to the BMS? maybe is a stupid question, but I can't find the answer in the forum, I'm not so clever with the search bar.. :x and the seller say to me that there is no problem..
Should I limit the continuous current of the controller to 30A max?
I just wanted to share my question with You,
Greetings from Madrid :)
* Lithium + Air = Fire * <-----> ** Lithium + Chemical-Additives + Air = ZERO Fire **
<Battery and EV works>
https://facebook.com/evmadrid1
<Battery building resources>
http://www.endless-sphere.com/forums/vi ... 14&t=68005
dnmun   100 GW
Re: 48V BMS 30A continuous 60A peak
Post by dnmun » Nov 26 2014 10:01am
that is the BMS that sunthing guy uses on his bigger battery packs. it should work for you if you have a 13S liion pack.
Nobuo   10 kW
Post by Nobuo » Nov 26 2014 10:01pm
Yes I will use that LG that have very similar specs as ncr18650PF from tumich.
But because I will put 14p. I could reach easily 60A continuous from my battery pack if my controller would let it.
Its only because, in such case, I don't understand the rating (30A continuous 60A peak) from the BMS :roll:
Nobuo   10 kW
Post by Nobuo » Nov 27 2014 1:22am
I will try to explain myself. :P
I have this controller. 48V rated at 45A max.
http://www.aliexpress.com/item/High-Qua ... 94528.html
I will have a 13s14p with those Lg cells or smiliar ncr18650PF that can give 10A max more or less.
and a 9c standart 1000w motor
http://www.aliexpress.com/item/High-Qua ... 13046.html
If a push throttle to the max. how much Amps I will be sending through the battery to the motor? :roll:
