i love the high amp Samsung cr18650 cells. I build battery packs and I can make them in any size or shape. I even got 15+ ah into the front hub of my tidalforce m750 and I have about 7000 of them on hand if anyone needs some. they are genuine, not the fakes on ebay. You should get about 1500 charge cycles before replacement. I also put them in an 2 ezip plastic battery packs for a friend. He says he gets about 50 miles on mostly flat ground.(we have lots of that here in Chula Vista, Ca. I also put them in a neighbors 4 wheel mobility scooter more than doubling the range at 50lb less. I believe these are the best all around cells on the market. Thats why elon stays with them. I also use only pure silver wire and silver tabs. Makes a big difference. Second only to tidalforce using high quality silverplated aircraft wire in their bikes.
We need to bury the internal combustion engine for good. ! they should have already been placed in a museum.
