Crystalyte HT3525 motor connector confusion
MurderousFrog   100 mW
Post by MurderousFrog » May 13 2015 6:52am
First post, don't know if I am doing this right...
I have recently ordered a HT3525 motor from crystalyte europe for my first e-bike build, and am quite puzzled regarding the connector type.
Here are some pictures of the connector plug:
I can't seem to find any information about this type of connector on the internet or ES, does anyone know what it's called?
Another thing, these pins seem awfully thin for a 3-6kw motor...
cal3thousand   1.21 GW
1.21 GW
Re: Crystalyte HT3525 motor connector confusion
Post by cal3thousand » May 13 2015 10:47am
I have never seen that connector. If you are not using their controller, just snip it and put your own favorite flavor on there.
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
docnjoj   100 GW
Post by docnjoj » May 20 2015 12:39pm
That looks like a sensorless connector with 3 phase wire connections. Did they sell you a sensorless controller too?
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
Post by MurderousFrog » May 31 2015 8:50am
Thank you guys for your help.
cal3thousand wrote:I have never seen that connector. If you are not using their controller, just snip it and put your own favorite flavor on there.
Did that, It does indeed have the hall sensor wires. After some further investigation on the plug, I found the 6 smaller hall pins which can be seen in the second picture of my post. Those little black spots in the edges.
dogman dan   100 GW
Post by dogman dan » May 31 2015 9:10am
Actually it is sensored. there are 6 tiny contacts around the outside edge of the plug. 5 halls, and the other could be a temp sensor. On the E-bikekit, when we used that type of plug, the 6th white wire was not used. No idea what it's called.
You need to either cut that plug off, and use some other, or find a wire with the male end plug on it.
This item would get you connected to the motor.
http://www.ebikekit.com/kit-components/ ... -trikekit/
And obviously, this plug is only good to about 1000w, maybe 1500 if you aren't doing long hill climbs. What is it doing on that motor, which often gets run at 3000w?
Use it only as your halls plug? then splice on bullets for the phases?
ebullitt   1 µW
Post by ebullitt » Nov 28 2017 6:50pm
Hello, Just got a Crystalyte G40 front motor with the same connection. Does anyone know how the 6 small pins are connected? Particularly, which too of them are the +5V and GND respectively?
Rienmachien   10 µW
10 µW
Post by Rienmachien » Feb 21 2019 5:18am
Well just to respond to this really old topic. Yesterday I received my order form crystalyte-europe as well. Apparently they dont update their webshop. Since I received the new type of the HS3540... This also has that odd plug on it. I contacted them and they told me they would make / have a adapter cable.
Their website states the motor is using anderson connectors and a five pole xlr.
Hopefully they will supply me with a odd connector >> anderson power and jst-SM for the sensors.
I dont understand why they dont just simply update their website. I guess thats less of a hassle than having all those customers contact you....
tanel_k   1 µW
Post by tanel_k » Feb 21 2019 1:40pm
Let me know how it goes with adaption cable. I just bought hs3540 also and saw this weird connector. Their support isn't very helpful, they don't want to sell/provide adaption cable without buying controller from them.
Rienmachien   10 µW
10 µW
Post by Rienmachien » Feb 22 2019 3:59am
tanel_k wrote:
Feb 21 2019 1:40pm
Well, the cable will cost me 25 euro and they added shipping to the bill so in total it will set me back 32 euros excluding taxes. Quite a bummer since it is not my fault they have old data on their website. Otherwise I would have ordered it straight away with the motor.
When you are the end customer (I bought it using my business to get a 20% discount) this is a non conformity and european law says they should or accept a return without costing you anything or help you solve the problem.
I think its no problem they charge me for the cable, I needed it anyways. But the shipping is quite rude.
