$14.99 72v Sunwin Controller
speedmd   100 MW
Re: $14.99 72v Sunwin Controller
Post by speedmd » Sep 25 2016 7:30am
Thanks guys, most likely to go with the fixed voltage as it is a more compact case going by the specs. Is it odd that it would pick up power at 30 MPH. Jerky throttle on the first unit? Is it possible that it failed the self learn settings of the motor or had a throttle issue? Looks like a good value if it holds up.
Ianhill   100 kW
Post by Ianhill » Sep 25 2016 10:00am
speedmd wrote:Thanks guys, most likely to go with the fixed voltage as it is a more compact case going by the specs. Is it odd that it would pick up power at 30 MPH. Jerky throttle on the first unit? Is it possible that it failed the self learn settings of the motor or had a throttle issue? Looks like a good value if it holds up.
What I meant was the scooters original controller was jerky, the sunwin revs quite nice, I swapped to go to 16s but with this controller I would say 12s is plenty for most on boost but I gonna push it but further but the motor needs a rewind first, Ive discharged 12s 16ah through it in 20mins it was a completely flat out harsh ride the controller was no warmer than the batterys and they were only mildly warm for the cost the whole scooter kicks arse it owes me around £300 complete I had the scooter for £90 :)
markz   100 GW
Post by markz » Oct 01 2016 2:31am
So the programmable angle is tossed out the window for these Sunwin controllers, is that the case?
I havent really been doing anything lately, other projects. Fall season, winters coming.
The only thing I am looking for is a small yet powerful DD motor, and I will use one of my two Sunwin controllers.
I have not yet hooked any of mine up. So I will have questions about wiring for sure.
Ianhill   100 kW
Post by Ianhill » Oct 06 2016 12:00am
Does anyone know the max Erpm of these controllers ? I have got 20000erpm and 8000 mechanical (3pole 9n6p motor) I think the motor is my limiting factor, I believe the controller switches to sensorless when in high speed turbo pursuit mode so what's the limiting factor then is it saturation, laminates and the structure of the motor itself or does the controller still play it's part I know current and voltage will limit my speed but what I'm interested in is the erpms ?
I'm wondering as to how well it could perform on a high pole count hub motor top erpms achieved any one ?
BeachRider2016   100 W
Post by BeachRider2016 » Oct 14 2016 6:40pm
So has anyone figured out the programming on these controller? I got a 48v1500w on the way
markz   100 GW
Post by markz » Oct 14 2016 11:25pm
BeachRider2016 wrote:So has anyone figured out the programming on these controller? I got a 48v1500w on the way
I doubt there is any programming with these controllers. But we can always hope right.
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Oct 15 2016 9:12am
You would think that if possible, Sunwin would be selling it as so. A programming cable for $10 probably would make more profit that the controllers do.
In either case, I wait to see if they are.
Dan
Post by BeachRider2016 » Oct 15 2016 9:55am
Ive had a typical 1000w controller came with one of the kits I got on ebay. I took it apart last night to take a few pics to share.
Also got a monsterous 24fets one to show its internal. I couldn't get a clear picture of the chip and didn't write down any info :cry:
After modded the shun with a solder piece of wires from a 10G wire, the Amperage went way up to 60A. So that's roughly 2800w goes into my 1000w hub. Speed didn't increase but torque went dramatically.
OEM has 28A but open up to 30A, I modded shun it went way up to 60A
wirings
12 fets
48volts so 63v caps
HY1707 fets
Post by BeachRider2016 » Oct 15 2016 10:01am
And here's the monsterous 24fets version:
size comparison next to 12fet
label
80v caps, 48v version. But there's 8 of them !!!!!
6 shuns capable, but only 4 on.
Board can go up to 180v !!!
backside, messy
programming slots
12 fets each side
lowly cheap P75AF75 fets but 24 of them!!!
KozmoK   1 mW
Post by KozmoK » Nov 07 2016 4:15pm
Greetings!
Love this thread. I picked up a SunWin 48V 2000W 24Fets. I hooked it up to a GoldenMotor BLDC 1.5kw. I am running a 48v Lithium 21ah pack with BMS. Its fast as hell on a new Baja MiniBike Build I am doing.
After just running it at a short period, the cable from the motor that has the hall cables + the small gauged phase cables is extremely HOT. The Motor is not even warm. Do you think by me getting the 2000w version and not the 1500w did this? I set the speed setting to Low (yellow and black grounded).
Temporarily I have some bolts holding the phase cables together with the controllers ring terminals. At that point its not hot, it doesn't get hot until 6 inches towards the motor. I am waiting for some gold plated 5mm bullet connectors to arrive to replace the ring terminals.
What do you guys suggest I do:
1) Take motor apart, replace phase cables with 8 or 10awg wires.
2) cut a shunt trace to limit the current on the controller (I read that people do that to slow it down)
3) just get the 1500w version and be done with it
Two Baja Mini Bike Conversions
(1) 48v Lithium Pack GA's, 2000w sunwin controller, 1.5Kw GoldenMotor
(2) 52v Lithium Pack 25r's, Kelly KLS7222H, Motenergy ME0201014201,
http://i.imgur.com/QeqfM6h.jpg
markz   100 GW
Post by markz » Nov 07 2016 4:35pm
Buy a Cycle Analyst
jase1979   1 mW
Post by jase1979 » Nov 07 2016 5:18pm
If the 3 speed switch isn't installed. Which speed will the controller be set to?
Thanks
KozmoK   1 mW
Post by KozmoK » Nov 07 2016 6:27pm
jase1979 wrote:If the 3 speed switch isn't installed. Which speed will the controller be set to?
Thanks
Someone posted here in the 15 or so pages that its "Medium" speed is default with nothing jumpered. I am not sure if its correct, but when I shorted Black and Yellow, I could tell there was a little less speed.
Black and Yellow = Slow
Black and Blue = Fast
Nothing = Medium
Ianhill   100 kW
Post by Ianhill » Nov 07 2016 6:34pm
KozmoK wrote:After just running it at a short period, the cable from the motor that has the hall cables + the small gauged phase cables is extremely HOT. The Motor is not even warm.
From what i understand the motors windings are in the stator a big lump of iron with good heat transfer properties but the phase wires coming Into the can are in the magnetic field but they are floating in air so they have worse heat transfer properties an heat gathers thats why its the first spot to melt on a phase is typically the start of the phase or the ends turns, So if the phase wires are floating in air coming into the case its good practice to use a thicker gauge than the winding to help with this weak spot, what you can feel is the heat dissipating along the cable try upgrading to a 8awg if it will fit more the better but keep a eye on the stator core temperatures.
markz   100 GW
Post by markz » Nov 07 2016 6:53pm
Simplest way is to cut the phase wires as it exits the axle, then install thicker wire.
Or you could go all the way back to the windings, but fishing all the wires through the axle of the motor can be a bit of finagling. If you like the motor, and you can find some PTFE Teflon wire then that is your best bet. And of course do 8mm gold plated bullets.
KozmoK   1 mW
Post by KozmoK » Nov 07 2016 7:31pm
markz wrote:Simplest way is to cut the phase wires as it exits the axle, then install thicker wire.
Thanks, its not a hub motor, but just a motor with shaft (goldenmotor BLDC-108) - so it might be easier to take a part. But I see the bigger the wire will help dissapate the heat from the smaller wire closest to the motor. I will try shortening the wire, it currently is 2ft long and I only need about 10" - will cut and and put in the gold plated bullets. It seems the phase wires are only about 12
999zip999   100 GW
Post by 999zip999 » Nov 27 2016 12:45pm
Bump
EHCanadian   100 µW
100 µW
Post by EHCanadian » Jan 12 2017 9:43am
Here is the 96v 1000w & 15000w Models
96v 1000w
Fet: IRFB4115 3329 2E 31
Caps: 160v 470uF
96v 15000w
Fet: IRFB4115 329P JS 21
Caps: 160v 470uF
Both have a cause of death. Blue phase tracers to fets obliterated. Exact same area as well.
Both where running 108v 20ah acid deep cycle.
The 96v versions have another pcb board on the VCC side on the pcb that the 60-84 do not have.
I have..
60v 1000 - Still running - Silent
72v 1000 - Still running - Silent
72v 1500 - Still running - Noisy
84v 1000 - Still running - Silent
96v 1000 - Blown - Silent
96v 1500 - Blown 1st one - 2nd one still running - Both sets are noisy
The noise may be due to the limit of the hub motors. Silent under 1500. Loud with 1500w controllers
stevc   10 W
Post by stevc » Jan 12 2017 7:27pm
Looks like the supplier I was buying from on ebay ( hksunwin ) is cutting right back.
markz   100 GW
Post by markz » Jan 12 2017 7:33pm
I see 417 items,
Searched "Controllers"
http://www.ebay.ca/sch/m.html?_ssn=hksu ... rs&_sop=15
Prices seemed to have risen a little bit. But otherwise I dont notice much difference.
stevc   10 W
Post by stevc » Jan 13 2017 12:59am
Must be coming from Australia thing, as shown by this link. (only 32 items)
http://www.ebay.com.au/sch/hksunwin/m.h ... pg=&_from=
Samd   1.21 GW
1.21 GW
Post by Samd » Jan 13 2017 3:29am
His prices keep creeping. Aussies get a good chance to bid due to odd hours
http://ballaratebikes.com/
markz   100 GW
Post by markz » Jan 14 2017 5:50pm
Can these sunwins run unsensored with no halls?
stevc   10 W
Post by stevc » Jan 14 2017 6:52pm
I think they only work with halls sensors.
Bikebrap   1 W
1 W
Post by Bikebrap » Jan 26 2017 6:20pm
Mine works in sensorless mode when halls get disconected
