Magura MT5e (Hydraulic Brakes) for E-Bikes and Pedelecs
GCinDC   10 GW
Post by GCinDC » Sep 09 2015 1:11pm
Just searching around for hydraulic brakes that fit next to a fat motor and found these. Has anyone seen or tried them? Or better yet have dimension specs?
The article says they'll be released this fall: http://www.magura.com/en/bike/products/ ... emein.html
I particularly like the part I bolded below:
MT5E FOR E-BIKES AND S-PEDELECS
FOUR-PISTON BRAKING POWER, NOW ALSO FOR E-BIKES!
The number one upgrade for e-bikes and speed pedelecs is targeting the booming market for e-bikes and speed pedelecs, which have power assistance up to 45 km/h, with the new MT5e.
Demanding All-Mountain and Enduro mountain bikers have already been convinced by the benefits, and these are just as important in traffic: the lightweight brake lever housing, made from MAGURA-exclusive Carbotecture material, offers superb ergonomics when combined with the special pedelec brake lever in die-cast aluminium. The ultra-rigid four-piston brake calliper, with easy brake pad replacement thanks to magnetiXchange pistons, provides superior braking power in any conceivable riding situation. And the legendary MAGURA Royal Blood fluid is not just more environmentally friendly than the DOT brake fluids used by many competitors, it also guarantees long-term low maintenance and therefore low cost of ownership.
MAGURA have come up with a groundbreaking new solution for the MT5e: a mechanical switch located right inside the brake lever. It activates the brake light even before the brakes actually bite, and this will also be useful for power assist systems with a regenerative braking mode, so that it can be engaged as quickly as possible. And should a crash occur, exchanging the unit is much cheaper than with our competitors, because the switch is located within the brake lever housing.”
The MT5e also uses the new Storm HC brake rotors. Compared to the previous Storm models these have even higher stability under load and greater mechanical strength. The new friction surface geometry of the brake discs, which are still 2 mm thick and available from 160 to 203 mm in diameter, provides optimum wear and noise performance.
The new MAGURA MT5e will be available from Autumn 2015 – and by then it will also be factory-fitted to numerous e-bikes and speed pedelecs.
ergonomic, 2-finger, aluminium brake lever
Carbotecture® housing & handlebar clamp
adjustable lever reach All-in-one,
4-piston brake calliper with banjo
magnetiXchange brake pistons for easy brake pad replacement
weight only 380 g
Compatible with all MAGURA HC and Storm SL discs
Color: Polished Black Anodized
Warranty: 5-year leakproof guarantuee for brake levers and cylinders after providing the original proof of purchase.
if anyone figures out where to buy, please provide link! :P
Youtube channel, 2013 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (11.6Ah), hs3540, Adaptto Mini-E, 900W BMSBattery charger.
GT I-Drive (sold), 20s lipo, 9C, 72V 45A 12FET.
Lurkin   100 kW
Re: Magura MT5e (Hydraulic Brakes) for E-Bikes and Pedelecs
Post by Lurkin » Sep 12 2015 12:35am
CRC sells magura brakes, but cannot see any ebike specific ones on there... maybe in time?
ozman   100 W
Post by ozman » Oct 17 2015 7:57pm
These look interesting hope they release them soon
Hillhater   100 GW
Post by Hillhater » Oct 19 2015 5:03pm
Not the best, and no switches in the levers ,....but I just picked up a complete set of new Shimano 335 hydros, for $25. (Au$35 ) !...from an online bike store.....( I wouldn't use the switches anyway !)
Obiwan007   1 kW
Post by Obiwan007 » Oct 23 2015 2:50pm
Hey Hillhater, what on-line store did you get that deal from on the Shimanos. When you say "set" do you mean front and back, of just one set of calipers and levers?
Hillhater   100 GW
Post by Hillhater » Oct 24 2015 5:18pm
The store was OO.com.au, http://www.oo.com.au/Cycling_C29.cfm?so ... tory=Price
And it was a full set, 2 calliper, pads, levers, piping assembled & pre bled, all in original Shimano packaging.
..but, they seem to be sold out now !
However there do seem to be similar sets on EBay for ~ $50 ish !
voicecoils   10 MW
Post by voicecoils » Oct 24 2015 10:04pm
Magura has been making ebrake hydro's for several years. Typically they are done in production runs for OEMs only and not sold through retail channels cause the demand just hasn't been there yet.
Looks like that's changing which is cool to see.
I've been running the MT5 front and MT2 rear for a few thousand km this year. I'm biased but the MT5 is an excellent brake and has very strong braking even on my quite long wheel base ebike. That said, the MT7 has noticeably sharper braking with less finger force, so if the switch wasn't necessary and price wasn't an issue, I'd prefer the 7s.
The new MT quad piston series compare very favorably to Zee and Saints if you've ridden those.
The S-pedalec ball end levers are a nice touch, much better to crash on
Lurkin   100 kW
Post by Lurkin » Oct 25 2015 4:19pm
In performance perhaps. But when I compared it recently, the best economic decision was Zee. The only advantage appeared to be the cut off, which didn't justify the additional expense.
It will be awesome when the prices come down....
