Cycle Analyst V3.0 diode short
eugen.gabriel   1 µW
Post by eugen.gabriel » Sep 10 2015 3:49pm
Hi all,
I am trying to find out the type of the diode that was burned on the cycle analyst V3. It is the diode D3 shown on the attachment. Can anybody help me with the type and where to buy?
I measured 150mV at the another diode D1, D2 and D4...
:D
Eugen
bowlofsalad   1 MW
Re: Cycle Analyst V3.0 diode short
Post by bowlofsalad » Sep 10 2015 4:23pm
eugen.gabriel   1 µW
Post by eugen.gabriel » Sep 11 2015 3:39pm
WOW!!! Thank you!!! that is exactly what I was looked for. I did not find it before. :roll:
dnmun   100 GW
Post by dnmun » Sep 11 2015 5:27pm
email justin and see if they have more of those little surface mount diodes. it is there for protection of the drain brain from reverse polarity so if you replace the diode with a wire it will be subject to failure if you reverse it again.
eugen.gabriel   1 µW
Post by eugen.gabriel » Sep 12 2015 10:04am
I have already mounted one from my old mainboardand that was the same size. It works fine!
The THUN X-Cell RT torque sensor is also mounted and connected.
jordison   10 mW
Post by jordison » Jun 10 2019 2:27pm
Hi guys.
I connected the positive to the ground of the CA,
Now the screen lights up but doesn't show anything.
Is the CA repairable?
Can anyone help me troubleshoot this?.
Smells a bit burnt but I don't see anything.
I measured the diodes :
D1 0,146
D2 0.146
D3 0.734
D4 0.152
Z1 0.996/ 0.838 goes both ways
Thanks in advance
