Page 1 of 1
Sabvoton SSC048150 - NAKED!
Posted: Sep 14 2015 3:55pm
by Kodin
I got bored and took the case off my Sabvoton 48V controller. I was curious what sort of components were inside. Guess what? 24 Infineon 4110's, and 100V-rated caps!
Photo dump below:
The two black things around two of the phase outputs look to be inductive pickups for sensing back-EMF. Interesting design.
Dat heatsink...
100V rated caps!
The springs cover it up, but it's 4110 Infineon's. (I lifted one of the springs to double-check, I just couldn't balance the camera, controller, light, and prying tool all at the same time).
Everything seems to be very well silicone-potted so that vibration won't damage components. Also note the rubber isolator between the metal post and the PCB. The PCB itself isn't actually screwed down at all, even though there's provisions for it. I wonder why?
Also noted, though there's a point for grounding to the heatsink, they seem to have opted not to install it. Not necessarily a bad thing, just means the heatsink is electrically isolated from any of the internal circuitry.
Again, no mounting screws used to anchor the board.
Here's a funny one! They scraped the labelling off of all the IC's other than the FET's:
The whole thing is VERY impressively sealed, rugged, and generally well-built. Hope you enjoyed the pictures!
Re: Sabvoton SSC048150 - NAKED!
Posted: Sep 14 2015 4:07pm
by dequinox
Lol just kindding, that's pretty cool. Shout-out to a fellow Oregonian btw.
Posted: Sep 14 2015 7:38pm
by Grizzl-E
Wow thanks dude! I was going to open up my 72080 just for kicks. You saved me the trouble to sate my curiosity.
Posted: Sep 15 2015 1:24am
by Kodin
One other observation. There's two LEDs but only one has a light pipe. Go figure.
Posted: Sep 15 2015 2:09am
by Doctorbass
Truely a copy of the Sevcon gen4 controllers layout!
Doc
Posted: Sep 15 2015 3:49am
by Kodin
Wait, seriously?
*does some googling*
Holy crap you're right! Casing even looks identical! Which do you think came first? Could even be these are the same units simply re-branded.
On second glance, the Sabvoton version uses standard molex connectors and seals from the back end of the connector rather than Sevcon's waterproof-at-the-plug design. Otherwise if I were colorblind I'd be hard pressed to tell the difference.
Posted: Sep 15 2015 4:32am
by nieles
Doctorbass wrote:Truely a copy of the Sevcon gen4 controllers layout!
Doc
lol yeah was thinking exactly the same. same fet and capacitor layout
Posted: Nov 21 2015 3:01am
by cwah
Are these good in real world testing?
Posted: Nov 29 2015 5:06am
by Kodin
I've yet to finish my custom motor mods so I can't tell you for sure; others have these however and love them.
