Frud
100 µW
I offer you my version of the graphical application for СА. To transfer data to the mobile device I am using serial 2 WiFi module ESP 8266. This option has some advantages over bluetooth.
1. Significantly greater range, particularly when using an external antenna. This allows you to use the application for telemetry.
2. A more stable connection.
3. Automatic connection.
However, there is a drawback - high power consumption of the mobile device. This is achieved using the optional DC-DC converter to charge your mobile device.
The current version of the following options:
1. Display of speed using a sensor or GPS
2. Indication of the voltage to 130 V
3. Indication of charge and discharge current up to 2000 A
4. Display the battery capacity percentage and Ah
5. Registration of peak current and voltage
6. Registration of the maximum and average speed
7. Daily odometer
8. Instant and average consumption Wh / km
9. The calculation of the range on the remainder of the charge
10. English and Ukrainian languages
If the theme is interesting, I will provide a link to download.
And while some screenshots
7. Daily odometer
