spdas said:
(...I sure like the idea of a controller designed to work hand in glove with the CA) Sure would save a lot of time.
Grin controllers are excellent, but do not provide any special design features to accommodate the CA beyond the CA-DP connector which can also be found on controllers from other sources. The design strength is rather exactly the opposite: it is the CA that is designed to provide full functionality with *any* controller -- regardless of whether that controller comes equipped with the special connector.
There are threads on ES describing adding a CA-DP connector to a controller in the manner that might be done by a manufacturer -- involving opening the controller and making internal modifications. That strategy frankly requires more time, skill, and risk than necessary -- Grin sells components that typically allow the CA-DP feature to be added externally with no internal controller modifications whatsoever.
Your Kelly lacks a CA-DP connector and will require an external shunt. Considering your controller current capacity, a good choice is the 'Shunt-CA3' molded external shunt (see: http://www.ebikes.ca/shop/ebike-parts/ca-accessories/shunts/shunt-ca3.html). Hookup of this shunt is addressed in the
CA V3 Unofficial User Guide. I have not personally wired up a Kelly, but I believe you find that the more complete and specific diagram below to be accurate. This arrangement of shunt, key switch, and kill switches leaves the CA operational if the controller is shut off with the handlebar kill switch, but there are several minor variations. See the UUG for details.
As you can see, all wiring is entirely external to the controller and involves only a few connections to readily available controller signals. This will give you full access to V3 features - battery and trip statistics, thermal rollback, programmable LVC, optional PAS support, 3-position limiting switch, etc.
