So 5T mxus at 120v with 45amps vs 5T mxus at 60v 90amps. I would think the motor would be much hotter on the 90amp setup right ? On the grin simulator they heat up at the same rate ? power in = heat , but i would have thought the amount of amps would effect this. surely 90amps is going to heat things up quicker.
In practice I ran the 120v configuration this morning, there was very little heat compared to the 90 amp run.
This would mean really we should look for highest volts and lowest amps we can get with a highest wind motor ? 120v is pretty lethal though, which is the only downside ?
80kmh top speed at 120v and very very quick acceleration with low heat is nice, but is it the best setup for the mxus. If i can keep heat down its nice, or im gunna die from shock ?
