__mike
Hi Guys,
I currently have a leaf 1500w hub fitted to a 2011 Giant Reign (DS). The bikes been electrified for 1.5 years now and used for light off road duties and has performed flawlessly with a 2.0 Maxxis Larsen TT UST tyre with stans sealant. I've previously had a great run with in the past before fitting a hub- no punctures for 3 years / topped up sealant once.
I haven't ventured out to the rocky single track trails (Kalamunda) I used to ride frequently until this weekend. I forgot to bring my pump and started out with around aprox 25psi in the rear tyre. 1km later dented the rim (Alex Supra BH ->DH rim) on a rock / ripped the sidewall. Ok my fault I know I needed a little more air but I didnt hit the rock too hard Repaired the following day with a tube fitted with sealant, drove 45min back to Kalamunda, 750m into the ride pinch flat. Remembered why I went tubeless 5years ago......
So......
I'm thinking along the lines if I had ~38psi in the rear and hit a rock hard im inevitably going to suffer the same fate running a smallish 2.0 tyre?. Replace tyre with a heavy DH specific tyre and go back to tubeless? Is it just a case of needing to have a higher profile and thicker side walled tyre so there is more give? I want to know from people who are running similar weighted hub motors (~7kg) who ride rocky terrain hard, jumps etc etc what sort of tyre and rim setup are you running. Motorcycle rims arn't an option this is a bike Yes mid drive may be better and a 8kg wheel isn't the best for smashing into a rock but its been a pretty bulletproof setup until now and went well on the trail while it lasted
Mike
So......
Mike
