andyjk
1 W
I've searched around for an answer to this issue, just wondered if anyone had similar issues to me programming the magic pie 5 via Bluetooth using the golden motor android app.
The MP is discovered and connects fine to my phone using the Golden Motor app, I can see the motor dashboard (speed, volts, amps, etc) and it also reads the speed controller parameters fine but when I attempt to change the low voltage cutoff and save the settings to the controller it doesn't seem to write the changes because when I re-read the program data back from the controller it just fills in the old settings (42V cutoff)
I've tried lots of times including turning off controller before reading the data, I just wondered if anyone has had this issue before?
Cheers
Andy
Cheers
Andy
