KT-LCD1 battery voltage setting
YonderGod
1 W
Sacramento, CA, US
Can anyone decipher these poorly translated instructions?
I'm running a 12s(44.4v) battery, so the default setting for a 48v battery shows my battery as low all the time. And I'd prefer 42v lvc if possible.
From the manufacturers manual:
P5 is power monitoring mode, when P5 setting is 0, the power monitoring is the
"real-time voltage" mode. Namely, it is the method to determine the battery capacity
based on real-time battery voltage. When P5 equals to a specified parameter, the power
monitoring is the "smart power" mode (this parameter is determined by the battery
characteristics, ordinary 24V lithium is generally is 4-11, 36V lithium is between 5_15). P5
setting ranges from 0-40
http://www.szktdz.com/en/news_show.php?article_id=374
From BMSbattery website: (they label it the S-LCD1, but I think it's the same thing)
Note: How to determine the value of the parameter P5 ? The formula is LVC+P5/3.77.
For 24V battery, LVC=20V, P5/3.77=1.
For 36V battery, LVC=30V, P5/3.77=1.5.
For 48V battery, LVC=40V, P5/3.77=2.
You can adjust P5 parameter by your own battery discharge curve.
https://bmsbattery.com/ebike-kit/548-s-lcd1-e-bike-lcd-meter-ebike-kit.html
Oh, I see. So the LVC isn't changeable on the LCD1.
P5 was set to 15 for me, I changed it to 0 and it shows full battery now. I'll see if it's more accurate over time and try 10-15 if not.
I still don't understand what they're trying to say how to calculate it.
LVC+P5/3.77
40+P5/3.77
P5/3.77=-40
P5=-150
And then they say
"For 48V battery, LVC=40V, P5/3.77=2"
soooo
P5/3.77=2
P5=7.54? (round to 7 or 8 )
That isn't an equation. It has to equal something, such as
(LVC + P5)/3.77=1
I don't understand why they are formating it like this, instead of just
P5=xxxxxx
Like if it was (LVC + P5)/3.77=1
then solve for P5 (if LVC is 40)
40+P5=3.77
P5=-36.23
If it was (LVC + P5)/3.77=0
(multiply both sides by 3.77)
LVC+P5=0
P5=-LVC
:roll:
The only thing I can think of that sort of makes sense if if you take where they say
"LVC+P5/3.77"
and
replace "P5/3.77" with "2" in their "formula"
and you get
LVC+2
40+2
42
The formula is useless
At 3.85V the capacity of a li-ion cell is about 50% (source http://www.powerstream.com/lithium-ion-charge-voltage.htm)
3.85V*13=50.05V
How I figure out my P5 setting.
After some trial and error i´ve found that the value of P5 for a 48v li-ion is around 23
I ride the bike until the battery voltage drop to 50V and set P5 for a reading 50% on display.
Continue discharging the battery to reach the lvc and check the lcd
i don't know where the inventer of this formula went to school.
but it look like chinese to me.
How to calculate this formula for a 72v battery ?
What is P5 stand for in this formula ?
72V,lvc=60v, P5 (that the :evil: i try to figure out) / (= divided by) 3,77 = ???
LVC = 60v
btw, anybody running a qs205 v3 on a kentung 50+A controller ?
For 24V battery, LVC=20V, P5/3.77=1. ie. p5 = ( BATV - LVC ) / 3.77 ... (24-20)/3.77 ~= 4/4 = 1
For 36V battery, LVC=30V, P5/3.77=1.5. P5 = (36-30) / 4 = 1.5
For 48V battery, LVC=40V, P5/3.77=2. P5 = (48-40) / 4 = 2
Bat = 72V
LVC = 60V
diff = 12V
P5 = 12 / 3.77 ~= 12 / 4 = 3.
Not sure but, I think the first time the display "sees" the pack Voltage, it needs to be high as possible. For fully charged 12S LiPoly, around 50 Volts. This gives the best chance that the values will be close to correct.
If the LCD1 is the same as the s-LCD5 and s-LCD3, then you change the low cut0ff value with a "C" setting. The setting "C value no. 12" to a setting of "0" drops the low voltage cuttoff by two volts - which is the maximum amount that it can be lowered from the LCD.
The range of values is 0 to 7 with 0 being -2v, 4 being default cutoff, and 7 being +1.5v
You'll need to check if s-LCD1 uses the same settings as the above two. I don't know if it does or does not.
A lot different. No voltage or watt readout. No LVC adjust. It only has five P settings, and P5 can only be entered as an integer. I dunno how one would enter 1.5.
The intent for it is to have the battery icon match what one expects for battery capacity. I believe a better method is to install a cheap wattmeter and watch the AH usage.
I have an LCD-1 on one bike and I run 36V or 48V on it. It seems to power up and apply a different LVC specific to the battery.
P5 doesn't affect the running of the bike at all. You can make it any number you want. It's just for showing the segments on the battery display to stop it jumping up and down with voltage sag.
