Hello everyone,
I'm having an issue with the output of the ebike Hub Motor Kit I bought from Luna Cycle. I would provide a link to the product but it appears they have recently removed it from their website. Basically it claims to be the same kit sold by ebikekit.com but at a much lower price. Here is a link to that product.
http://www.ebikekit.com/electric-bicycle-kit/electric-bike-conversion-kit/electric-bike-kits/rear-500w-geared-motor-kit/
I have the kit installed on my bicycle and I'm using a 4ah 36v/40v powertool battery for testing. The battery is designed to run high output electric chainsaws and movers. The battery is brand new. With the 36v battery I'm not getting near the advertised speed under zero load.
My fear is that once I get the bicycle on the road, the actual speed is going to be much lower. With a 36v battery I was told to expect speeds of 20mph. I have plans to build a 52v battery as the final solution for the bike but my fear is that the performance is going to be very underwhelming. With a 52v battery, I was told to expect speeds of 30mph which would be more than enough for what I need. Honestly, 25mph should be fine.
Do you think a 52v battery will give me the output I'm looking for?
Is there anything else I can do to troubleshoot this setup? I've contacted Luna Support and they said the battery I'm using isn't adequate for testing which I don't believe is true. These battery packs are built usinghigh quality high output 20ah cells. I've also tried running 3 2ah 36v/40v in parallel to build a 6ah battery and I got the same results.
Here are some pics for reference.
Battery hooked up.
Battery Voltage
Controller Reading at full assist and Zero load
Any input would be greatly appreciated.
Battery hooked up.
Battery Voltage
