Temperature meter that work with KTY-84 ?
Doctorbass   100 GW
Post by Doctorbass » May 13 2016 6:20pm
any idea?
I want to add a monitor on teh temp sensor of my integrated Zero motor.
any of you know a meter that take these?
Thanks!
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
teklektik   10 GW
Re: Temperature meter that work with KTY-84 ?
Post by teklektik » May 14 2016 2:17pm
I think you're out of luck.
I once saw a nice 'anything' LED panel meter on eBay that had a programmable y=mx+b type voltage calibration/calculation which would be perfect for your application (actually 'temp' one of the uses they called out) - but I never saw it again. Looked like one of the standard LED panel voltmeters but with different programming. Bummer.
It's probably not what you want to do, but you might swap the part with an LM-35 which would allow you to read the temperature directly on any voltmeter. One of the many little LED or LCD meters on eBay might fit into your dash panel/instrument cluster.
teklektik   10 GW
Post by teklektik » May 14 2016 2:52pm
Aha!
Here's something for about $12 like the meter I saw on eBay -- the y = mx+b style meter.
This should work - I didn't plow through the parameter ranges, etc, but you are basically dealing with b=(voltage offset at 0 degC) and a m=(degC/V). If you use a 5V reference supply, you can use the calculated values on the CA V3 download post (see the snapshot of the spreadsheet).
programmable meter.png (66.14 KiB) Viewed 813 times
Doctorbass   100 GW
Post by Doctorbass » May 14 2016 11:37pm
teklektik wrote:Aha!
Nice find. In fact this is to install on my Zeromotorcycle. I need to know the motor temp and it use a KTY84 inside witch i can not replace.. Motor is a pain to remove and open.. i need temp reading for drag racing purpose.
in fact i was looking for that exact type or PROGRAMMABLE meter..
thanks!
Doc
pwd   100 W
Post by pwd » Jan 13 2018 9:20pm
Old thread I know, but I have the same question. Has anyone tries that ME-DV31423 meter? I have a LeafBike 1500W motor with a KTY 84-130 PTC thermistor that I would like to read the temperature from.
Current Build:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ WCEC 18fet
em3ev 14S5P 30Q + 14S6P 25R pack
Build Thread: https://endless-sphere.com/forums/viewt ... =6&t=98286
Old Build:
GIANT ATX 980 w/ Cycle Analyst v2.25
Golden Motor Magic Pie (internal controller) X2
14S3P 15aH: 6X 6S 5000mAh + 3X 2S 5000mAh LiPo pack
pwd   100 W
Post by pwd » Feb 06 2018 4:06pm
Bump :pancake:
Current Build:
Old Build:
