W1R3D
Hi Guys,
I am in the desperate need of some technical help and advise regarding the choice of shunt for my CA and current setup.
Firstly I have my self to blame as I mistakenly ordered the HC model and now need a shunt in order to wire in my new toy.
I understand that there is a calibration setup with CA but first I need to know if the shunt I was advised will suit my application.
I am not a electrical technician and have been pushing my knowledge and learning a heap since starting my first ebike.
Motor
1000 watt rear hub motor (Chinese special)
Controller
48 Volt 30 Amp no LCD just a twist throttle (Chinese special again)
Batteries
2 x 22 Volt 6 cell Multistar LIHV from Hobby King. Which I charge to the higher LIHV specs
The shunt I was advise from my local Jaycar specialist was a 6-50A 50MV shunt, I am not sure if it will be able to be reliable and was the correct choice...
Any help would be greatly appreciated
Motor
Controller
Batteries
