It's easiest to look at the RPM / Volt
Depending on the bike of your choice, the wheel size, your budget for batteries... etc.. you have plenty of choices.
From 404 to 4013 and 5302 to 5305
The higher count wind motors are slower. ie: 404=fast 4013=slow
I think alot of people overcomplicate things. Just like you can have a car with 4 cylinders or 8 cylinders.. if both are 2 L engines they have the same potential of power but will operate differently .
When you assemble a combination of motor/battery/controller/bike there are combinations that work better than others.
If you pick a combination that spins at 100 km/h, but don't have enough battery on board to reach anywhere close to that.. the slightest touch of the throttle will use the maximum amps allowed by the controller.
On the other end of the spectrum.. slap a 4013 into a 16" wheel at 36v you might have a top speed of 10 km/h, and will likely never reach a 20 amp draw even going up hill with the brakes on ! lol..
I'm having a hard time finding an easy way to explain all this.. but long story short.. pick a motor that matches your realistic cruising speed in your wheel size and it will work well.. Pick incorrectly and you will burn up batteries and controllers and end up with reduced range.
