upgrade for cheap "wiring block"???
shr00m   10 W
Post by shr00m » Jun 09 2016 3:23pm
what is a good replacement for the plastic box that has 3 bolts in it to connect the motor to the controller the one that came with my kit seems very cheap and id rather replace it before it falls apart on me and something bad happens.
Gregory   100 kW
Re: upgrade for cheap "wiring block"???
Post by Gregory » Jun 09 2016 6:31pm
I'd say for phase wires most people are using the larger bullet connectors (with a sheath of heatshrink), or Anderson Power Poles.
Or just solder them together if you never need to separate the controller from the motor.
1) x5305 Hub Motor in a 24" Sun rim with 10G spokes, Kelly 72601 controller, 74V 10Ah Turnigy LiPo 20C Battery and CycleAnalyst
2) Mac 10T rear hub in a 700C "comfort bike" 15S 5Ah LiPo, stock 28A Xie Cheng controller
3) 38" Longboard, Turnigy 6374, CC Mamba XL2 ESC
shr00m   10 W
Post by shr00m » Jun 09 2016 7:52pm
I'd solder but worry about flats... Bullet connectors would work.
Black6spdZ   100 mW
Post by Black6spdZ » Jun 09 2016 8:18pm
I'm rebuilding my old hub motor with a bad wire, installing new skf bearings, lm335 sensor and new 12ga wire. I will use either 4mm or 5.5mm bullets on the power wires but what do you think about using a 6-conductor cable with RJ25 terminal for the hall and temp sensors? I don't like the bulky cheap chinese connections
Raged   1 kW
Post by Raged » Jun 09 2016 9:01pm
RJ25 connections dont like vibrations. You'd need to plug it in then glue it for a semi-reliable connection. Even then, you still couldnt trust it on rough terrain. I'd personally look at the smaller waterproof plugs like the HiGo which is nearly the default for alot of ebike kits (it's quite expensive though).
Focus Black Forest 29er - MAC10T 14S Lipo - 50km/h, 50km range. (dead)http://endless-sphere.com/forums/viewto ... 91&start=0
Cube Reaction 29er Cyclocross BBS02 http://endless-sphere.com/forums/viewto ... =6&t=70549
Black6spdZ   100 mW
Post by Black6spdZ » Jun 09 2016 10:13pm
Raged wrote:RJ25 connections dont like vibrations. You'd need to plug it in then glue it for a semi-reliable connection. Even then, you still couldnt trust it on rough terrain. I'd personally look at the smaller waterproof plugs like the HiGo which is nearly the default for alot of ebike kits (it's quite expensive though).
how about this? http://www.ebay.com/itm/IP68-M14-Waterp ... SwpDdVaDDr
mybike   100 W
Post by mybike » Jun 10 2016 10:07am
Yes could work but that will depend how much amps it will handle before melting and wires touch :roll:
I personally use Terminal Block 40-60Amp never had any issues.
teklektik   10 GW
Post by teklektik » Jun 10 2016 12:08pm
Nope.
Just building in a recurring PITA.
The nice thing about plain old JST's is that you just slide the pins out of the shroud so you can pull the wires+pins through nut, washer, etc for motor service. Everything just clicks back together.
Black6spdZ   100 mW
Post by Black6spdZ » Jun 10 2016 12:33pm
yea that would be a PITA. I've ordered an assortment of JST SM connectors to build my project. Thanks for the input
