LTB: Split cassette removal tool
walawn   1 mW
Post by walawn » Jun 26 2016 9:18am
Hello everyone. I am looking to buy a cassette removal tool that has already been cut in half. I have a 2016 Radrover with a 750W geared Bafang hub motor and 7-speed Shimano cassette. I just bought a 11-32 Nickel-plated cassette but cannot change it out because of the wire coming out of the axle. I don't want to cut and splice/solder the wire. If anyone has a specail tool for ebikes with hub motors, please PM or reply. I'm willing to pay top dollar just to get my new cassette on. Thanks!
Voltron   1 MW
Re: LTB: Split cassette removal tool
Post by Voltron » Jun 26 2016 9:39am
If the motor wire plug is small enough to go thru the cassette, you should be able to dremel out the hole in the tool. I clamped mine in a vice and went at it with the mini drum attachment, only took about ten minutes.
Warren   100 kW
Post by Warren » Jun 26 2016 1:43pm
The freewheel removal tool, sold by EM3EV, has a 17.6 mm hole (18 mm if you scraped off the cheap plating) that allows passage of any connectors I know of. It is designed to fit Shimano, and DNP freewheels.
I just found a picture o a 750 watt Bafang I have never seen before. It, like all I am aware of uses a freewheel, not a cassette. However, unlike those I have seen before, the wires come out the freewheel end of the axle, and it has a huge plug!
http://www.aliexpress.com/item-img/BaFa ... 21714.html#
walawn   1 mW
Post by walawn » Jun 26 2016 2:50pm
Warren wrote:The freewheel removal tool, sold by EM3EV, has a 17.6 mm hole (18 mm if you scraped off the cheap plating) that allows passage of any connectors I know of. It is designed to fit Shimano, and DNP freewheels.
Could you provide me the link? I want to make sure that I order the right one. Thanks!
Voltron   1 MW
Post by Voltron » Jun 26 2016 4:53pm
It looks like the plug is enlarged to show detail. They use that same plug on a few brands now...super hard to probe the pins in there for troubleshooting
walawn   1 mW
Post by walawn » Jun 27 2016 10:54am
That's the same motor in my $1500 Radrover
Jon NCal   1 kW
Post by Jon NCal » Jun 27 2016 11:11am
If your bike has a Shimano freewheel, then you can get a DNP Freewheel remover tool with a thin wall at Amazon.
mich63lk   1 µW
Post by mich63lk » May 12 2018 5:05pm
Just easily dismantle the freewheel from the top and remove the core with a wrench. https://www.youtube.com/watch?v=WsVL1XqZve8
radrover, radmini, bafang 750w rear hub motor freewheel tool remove
