johnnyz
Ok ..I bought a Motorino XMR.
Looks like a real motorbike..handles extremely well, great ride and comfortable..real motorcycle tubeless tires 4.5 inches wide!
72 volt, SLA..Sinewave 12 Fet controller drawing max of 30 amps, weight 245 lbs (90 of that is the batteries )
Disconnected the governor and will do about 55-60 kph. A bit slow on acceleration, (my recumbent trike with 92 volt lithium 18 fet Crystalyte controller pulling 65 amps on a Crystalyte H4080 24 inch wheel pulls about 3 times as hard and a max speed of around 80 kph)
Heres the thing...On my trike on a hot day getting up to speed sometimes the motor gets so hot you cant touch the side plates of the motor..on this bike, ive done the same thing and the side plates are barely warm...its a beefy motor, bigger and wider than the H4080.
QUESTION: Does anyone know anything about it?...pictures included...as Motorino wont tell me.
Im thinking of supplanting the headway cells or maybe some RC Lipo cells in a 92 volt configuration swap out the controller for my Crystalyte 18 fet..and this thing should experience a sizeable increase in performance..the difference between this and standard bikes being modified with hub motors is its much much safer, with far superior handling..and with the modifications will come about 50 lb reduction in weight.
Looking forward to comments..
john
john
