fork installistion, ring too big?
mudale222   10 W
Post by mudale222 » Jul 04 2016 7:49am
Raged   1 kW
Re: fork installistion, ring too big?
Post by Raged » Jul 04 2016 8:13am
You have the wrong size crown race. The crown race you have looks like it might be for a tapered steerer. The crown race needs to match the headset. Eg. if your headset is tapered and your fork steerer is straight, you need a crown race adaptor (about 5 from chain reaction or $10 from your bike shop).
Take a picture of your frame to see what type of headset you use... this will determine crown race model.
Focus Black Forest 29er - MAC10T 14S Lipo - 50km/h, 50km range. (dead)http://endless-sphere.com/forums/viewto ... 91&start=0
Cube Reaction 29er Cyclocross BBS02 http://endless-sphere.com/forums/viewto ... =6&t=70549
mudale222   10 W
Post by mudale222 » Jul 04 2016 8:49am
Raged   1 kW
Post by Raged » Jul 04 2016 10:23am
on the frame page it says :
Headset - Headset is included. High Quality semi-integrated, sealed bearing, original Taiwan VP Components J305AC(S) headset, compatible with standard bicycle 1,1/8 and also tapered forks (two different bottom rings included).
For the EBB frame you should have gotten this as part of the kit :
Do you have the big bearing ( at the end ) aready inside the bottom of the headtube?
Also Read this :
http://www.fullspeedahead.com/wp-conten ... ctions.pdf
mudale222   10 W
Post by mudale222 » Jul 04 2016 10:39am
yes. the biggest bearing is at the bottom and the bit smaller bearing (2 from the right) is at the top of the headtube.
Raged   1 kW
Post by Raged » Jul 04 2016 10:46am
mudale222 wrote:yes. the biggest bearing is at the bottom and the bit smaller bearing (2 from the right) is at the top of the headtube.
I think you only need this then :
http://www.chainreactioncycles.com/au/e ... -prod92344
That taps onto your fork and lines up on the bearing at the bottom. Make sure you get the 2015 onwards ( 45 deg angled one ). As mentioned before... your LBS should have one if you're in a hurry.
edit. actually.. that cup might be your reducer for the bottom... But you would need another bearing... Maybe someone with the same kit you have can chime in,
mudale222   10 W
Post by mudale222 » Jul 04 2016 3:41pm
Never mind.. i was an idiot. One peace was combine from two separate peaces and i didn't notice that...
It was the low crown and the upper ring.
Now it's all good
thx :!:
a bit annoying that at the left side it's look sunken
