camerons98
Few details about the bike:
-MXUS 3000W V2
-LYEN 18 fet controller
-20S 11aH 18650 pack
Okay so I went to repair my bike after my accident last year where the wheel fell out the dropouts...
After I put everything together and tested the throttle the wheel stuttered a few centimeters then froze.
First instinct was to swap the blue and yellow hall and phase wires which resulted in the wheel starting to spin but stuttering madly.
https://www.facebook.com/cameron.straughan.1/videos/1429805153702430/
I then pulled out the hall tester and spun the wheel, this was the result...
https://www.facebook.com/cameron.straughan.1/videos/1429856167030662/
I knew something was wrong with one of the halls, I pulled out my multimeter and plugged in the pack and started measuring.
Ground to power was fine, constant 4.4v..
Ground to Green was fine, flickering between 0 and 5v when wheel spun..
Ground to Blue was fine, flickering between 0 and 5v when wheel spun..
Ground to yellow wasn't fine, it stayed at a constant 5v no matter where the wheel was positioned...
Now does this mean there is a short somewhere or is the hall sensor itself just knackered?
All help is appreciated, thanks. Cameron.
-MXUS 3000W V2
