multifrag
Would love to get any recommendation on 26' bicycle rims for hub motors. Gonna be using Sapim Strong spokes with a 9c motor
wesnewell said:Depends on what size tire you plan to use/ For 1.95-3.0" I'd go with either a 32-35mm inside width, like Weinmann DH39 or DHL42, Alex DX32.
multifrag said:Would Mavic XM319 Disk rim work alright. It should be good for the price. From the calculator it shows that I will need 162mm Sapim Strong spokes
Drunkskunk said:multifrag said:Would Mavic XM319 Disk rim work alright. It should be good for the price. From the calculator it shows that I will need 162mm Sapim Strong spokes
While Mavic makes good rims, that rim is a skinny little thing. The bead width is just 19mm. Collective experience has shown that wider rims do better on bikes for everything except aerodynamics. So unless you plan to run a very skinny tire, pass that one up.
I wouldn't recommend a rim unless I knew what kind of riding you planned to do, and what size tire you were going to use. However, the Alex and Sun Ringle rims would probably have been on my list.
Just remember to check your buying a rim with 36holes or you're going to be putting yourself into quite a hub lacing challengemultifrag said:Would love to get any recommendation on 26' bicycle rims for hub motors. Gonna be using Sapim Strong spokes with a 9c motor
and/or weightDrunkskunk said:...Collective experience has shown that wider rims do better on bikes for everything except aerodynamics. ...
multifrag said:I'm running 26' 1.5 tires. I tried getting the alex rims, buit nobody is selling them in UK
999zip999 said:http://www.jensonusa.com/Alex-DM24-Rim $ 23.00 I run this with muxus 3.000 7,000 watts. Works on the street and light trails. Breaks spokes on the rattlesnake trail.
I've been trying to find these in the UK for a while now and have all but given up!Ykick said:999zip999 said:http://www.jensonusa.com/Alex-DM24-Rim $ 23.00 I run this with muxus 3.000 7,000 watts. Works on the street and light trails. Breaks spokes on the rattlesnake trail.
No 26" only 24"
I'll repeat, if anybody finds Alex DM24 rims in 26" variety, please post a vendor link as I would love to buy a couple more. Thanks...
