Knuckles
The Infineon has Regenerative Braking built into the software programming.
Turns out it was there all along. I could never get it to work, however, because I run at 72V.
Well I hacked that limit. The Infineon is programmed to limit regen voltage to a max of about 60 volts.
So for a 48V battery system (that will accept a reverse current) the regen was there all along.
I am able to increase the MAX regen limit up to about 85V.
I do this by "tricking" the MCU by altering the R12 LVC resistor.
Regen Braking can be programmed to work with the eBrakes and the throttle.
It is activated by jumpering connections on the Infineon pcb.
Jumping (or connecting a switch) from BK to GND activates the Regen braking feature.
So for now ... I can re-program the Infineon to have an LVC= 29V with a max regen voltage of just under 90 volts.
At the max programmable regen value it really slows the bike down (to a dead stop).
All the energy goes back to the battery. I can basically "brake by wire". Very cool.
Other available programmable features on the Infineon are ...
LVC Settings
Max Current
Cruise Control
Multi Speed Function
Reverse
LVC Settings
Max Current
Cruise Control
Reverse
