Hi Guys,
I have an Infineon 40A 12fet controller, a 14s battery and a MAC Motor. Yesterday I plugged and unplugged the throttle pin from the controller in the adaptor/connector to play with my arduino and check some throttle control loops. I then went back to the original configuration and connected back the original pins between the throttle and the controller. After driving the bike for maybe 500m, it just suddenly stopped reacting to throttle inputs. Everything on the Cycle Analyst seems to work fine, but there is zero reaction to me twisting the throttle. I checked the throttle signal voltage and it is fine just as before.
Would anyone be able to help me on how to handle this issue?
Thank you for your help!
