tonystark20
I'm planning a new tadpole trike build, I'm trying to figure out the best way to set up the motor an battery
option 1
crown motor laced to 19" motorcycle rim (11.1kv motor)
battery 48v 60ah 40-50A continuous
option 2
crown motor laced to 17" motorcycle rim (8.8kv motor)
battery 96v 30ah 40-50A continuous
questions:
If i put 2 48v batteries in series will i be able to pull more amperage? (the 48v battery is rated @30A continuous)
good supplies/ model numbers for 96v motor controller (possible use of Lyen controller?)
what do you think would be the most effective/efficient set up?
is there a different motor/battery configuration I should look at?
maybe do 72v custom pack?
I do enjoy speed but most of the time I drive 40km/h and use the trike for range/commuting I have used the golden motor pie 5 at 1200w and for the post part it was fine, but it slowed down a little more than i would have liked on the hills.
The motor would be on a custom recumbent tadpole trike frame, will motorcycle rims all around, and DOT rated tires. total weight would be about
I already own a 48v 30ah LiFePo4 battery which is why im looking at 48v vs 96v systems
Thanks for suggestions/help
option 1
option 2
questions:
