I have got told by 3 different people now (my father, a preast and another engineer), that my actual disc brakes (203 mm in diameter from Tektro) are undersized for my ~40 - 45kg heavy bike. Compared to scooters and enduros (~120kg; 125cc) which weight about 3 times more, the weight of such a tektro brake (200 gram) is pretty much nothing, as with such weight of material it is quite unrealisitc to transform all the moving energy in heating energy / thermal energy.
All of those 3 people told me that when I have bad luck, the disc brake will overheat and block my (rear- or front-) wheel and / or won´t be able to take any heat anymore which results in a not working brake in a maybe emergency - situation
What do you guys think?
Let´s do some little math:
weigt of the disc brake:
0,2kg
specific heat absorption capacity of metal:
460 Joul / kg.
> spec. heat absorpt. capacity of 0,2 kg disc brake:
=92 Joul
Speed: 45km/h (ok, let´s say 60kmh to be realistic):
16,6 m/s.
The deceleration in an emergency brake (half of the speed in meters) => 30 meters:
4,2 m/s²
weigt of bike + rider + gear of the rider:
110kg
But how to go on? Maybe someone is more familiar with this, then I am?
