Page 3 of 7
Re: Specific heat absorption capacity of disc brakes
Posted: Feb 03 2018 3:45am
by eCue
The TRP Spire disc is working well in every respect. Solid feeling smooth without vibration quiet make that dead quiet and with good modulation.
Currently waiting for a bottom bracket cable guide to get the rear roller brake operating. Ive been using front disk exclusively these last few days. At first tried the brake lever in roller brake mode for a day.
It was spongy and required too much force to stop. Impossible to lock up in error and had a very long braking distance. Rather dangerous
V-brake mode felt so much better having both a sharp pull when needed and nice modulation. I have not had a error lock up and dont think I will. The Organic pads are silent and smoother then smooth , I can see why they are suggested up front.
Posted: Feb 03 2018 2:31pm
by Chalo
eCue wrote:
Feb 03 2018 3:45am
My favorite levers to use with drums and roller brakes have been adjustable gain linear pull levers, like Avid Speed Dial or Dia-Compe PC-7 EXA. However, I feel that long blades are an advantage in this application, and linear pull levers generally have short blades.
So-called "compressionless" brake cable housing is really good at improving lever feel and brake response with drum or roller brakes. I didn't believe it until I tried it.
Posted: Feb 04 2018 2:44am
by amberwolf
Chalo wrote:
Feb 03 2018 2:31pm
Is that the kind with the full-housing-length "wires" paralleled around the circumference of the housing? (rather than the spiral-wrapped type)
Posted: Feb 04 2018 10:04am
by Chalo
amberwolf wrote:
Feb 04 2018 2:44am
Chalo wrote:
Feb 03 2018 2:31pm
Yes, but it differs from index shift housing in that the parallel wires are contained in a snug Kevlar jacket to keep the housing from bursting under high compressive load. Here's the kind I use.
I had encountered long lay cable housing before that promised compatibility with both brakes and shifters; it was marketed by Odyssey. But that stuff definitely wasn't stiffer in compression than good quality Bowden cable housing.
Posted: Feb 05 2018 12:42am
by Raisedeyebrows
I have the Jagwire housing on my cargo bike with BB7's, the stuff is worth the money, really stiffened up the braking response.
Posted: Feb 07 2018 8:03pm
by Chalo
Prototyped a new fork today for a super- heavyweight pedicab. We opted for dual 203mm discs, which was the main reason we had to make our own fork.
That's a 29x2.1" tire on a 42mm wide rim.
Posted: Feb 07 2018 9:35pm
by speedmd
Nice! Like the look of the rotors mounted backwards.
Posted: Feb 07 2018 9:39pm
by Chalo
speedmd wrote:
Feb 07 2018 9:35pm
Yep. Good thing there are no calipers on it yet.
I'm on the lookout for reasonably priced 8" rotors with a non-directional pattern to prevent the inevitable reverse installation of the symmetrical wheel by end users. Any ideas?
Posted: Feb 07 2018 9:47pm
by speedmd
Brakco? Closer to a bi directional design. Float points and outer slots not.
https://www.ebay.com/i/282773086090?chn ... 2056669164
Posted: Feb 07 2018 10:25pm
by speedmd
The Ashima looks to be more symmetrical at the float points.
https://www.ebay.com/itm/Ashima-Flotor- ... SwEetWAvqN
Posted: Feb 08 2018 9:57am
by speedmd
Origin looks to be fully symmetrical, but possibly some cbore at the mounting screws. Not sure outer slots on the lower cost option would be a issue. KCNC also with a nice lightweight design. https://www.ebay.com/itm/Origin-8-Speed ... SwVqlaHClC
Posted: Feb 08 2018 11:53am
by Chalo
Thanks for finding these.
Posted: Feb 08 2018 12:25pm
by speedmd
Chalo wrote:
Feb 08 2018 11:53am
No problem. Like the idea of dual rotors, have been playing with the idea and glad you posted as we have many near moto requirements here that can test these lightweights out for suitability. Even if you need to get some outer rings water jet'd out a bit more heavy duty, the center hub may become a standard for most here on ES.
Posted: Mar 09 2018 3:16am
by Lebowski
Lebowski wrote:
Dec 14 2017 7:56am
I agree with Chalo about rim brakes... I mean disc brakes are getting larger and larger diameter, only a few more years till the disks are as large as the rims.... at which point everyone will realise rim brakes are basically disc brakes with the biggest disk possible.
:shock: just went through the rim...
Posted: Mar 09 2018 3:50am
by justin_le
Lebowski wrote:
Mar 09 2018 3:16am
Ha ha, funny timing. I've done that a few times myself and witnessed it countless times on customer ebikes.
There's a reason for disk brakes. But the ultimate solution for ebikes, of course, is GOOD REGEN!!!!
Posted: Mar 09 2018 5:26am
by Lebowski
I have good regen :mrgreen: just not on this bike.
This one is a non-ebike which I use 2-3 times a week to climb the local 350 m high hills. Then on the descent I am lightly on the brakes to keep speed around 40 kmh. I am happy that I didnt do a strong brake action, pushing through the rim locking the wheel. I think the wheel has around 20000 km on it...
Posted: Mar 09 2018 1:43pm
by Chalo
Lebowski wrote:
Mar 09 2018 3:16am
Lebowski wrote:
Dec 14 2017 7:56am
When I lived in Seattle, it seemed like year-round commuters would grind through their rims every year or two. Here in Austin, it only rarely happens, mostly to MTBers who intentionally ride in mud. Seattle's dirt is more abrasive, and it's wet and gritty most of the time.
I can say that in more than 200,000 miles of cycling, mostly with rim brakes, I've never worn out a rim sidewall.
Posted: Mar 09 2018 2:48pm
by Voltron
From a recent wheel that came in... he was a Canadian transplant and running high psi tires, which seems to be a commonality in the rim failures I've seen.
Posted: Mar 09 2018 3:18pm
by Chalo
I did that in the distant past, running 140psi in 700x28 tires.
I don't exceed pressure ratings anymore; I just use tires that are big enough for the job.
Posted: Mar 09 2018 3:32pm
by liveforphysics
Odd folks think your rotors are mounted backwards. As a man who has overheated and wadded up a half dozen bicycle brake rotors into a hot mess of steel, I found mounting them they way you did so it pulls on the rotor spokes vs pushing on the rotor spokes enabled them to survive much longer at extreme temps.
Chalo wrote:
Feb 07 2018 8:03pm
Posted: Mar 09 2018 4:15pm
by DanGT86
Iv'e also always thought rotors should be mounted that way as well. Seems like in the case of a catastrophic rotor failure you would want the "spokes to fold away to a smaller radius rather than growing to a larger radius and stabbing everything. I guess its probably silly to try and apply logic to such a chaotic event.
Posted: Mar 09 2018 4:24pm
by Chalo
liveforphysics wrote:
Mar 09 2018 3:32pm
In the picture, they are backwards relative to their directional markings.
I think the idea is that leading spokes exert an expanding force on the outer ring of the rotor, which helps keep it straight by means of hoop tension. Trailing spokes contract against the outer ring, promoting buckling. I don't know how much of this is founded in test results.
The first disc brakes I owned in the early '90s were Mountain Cycle Pro-Stop 9" full floating cable-hydraulic brakes with hard anodized aluminum rotors. They were labeled specifically to have trailing spokes when mounted, contrary to common practice today.
I figure I'll mount them the way the manufacturer suggests, all the while wondering why more disc rotors don't use a non-directional pattern.
Posted: Mar 09 2018 5:42pm
by speedmd
Mar 09 2018 3:32pm
[/quote]
I have used them both ways for a bit also. Never had a fail. Then I started seeing photos of the fails.
Posted: Mar 10 2018 12:33am
by DanGT86
Wow. I'm not an engineer but as a machinist I dont like anything about that rotor design. In my experience with steel you typically want to avoid sharp corners and avoid thin sections that concentrate heat/stress. That rotor looks like the worst possible design for the heat and loads it would be under. Just eyballing it though.
Posted: Mar 10 2018 7:09pm
by liveforphysics
Buckling the spokes from compression in a rotor happens way easier than pulling on them until tinsel strength failure.
You really want some offset in the spokes vs being radially arrayed, but just like in a bicycle wheel you want to be pulling on the spokes and with a hub exit offset.
Most bicycle brake rotors I've seen looked like they had artists make the designs to look flashy rather than doing a mechanical stress optimization.
