use 48v 20ah on rc controller
jet8743   100 mW
Post by jet8743 » Feb 10 2009 3:22am
hi,
can i use a 48v 20ah ping batterie on this controller
wrobinson0413   1 kW
Re: use 48v 20ah on rc controller
Post by wrobinson0413 » Feb 10 2009 2:13pm
EV GLOBAL, Crystalyte 5304R26, 48V-100A controller design
jet8743   100 mW
Post by jet8743 » Feb 11 2009 2:28am
ok
even when I tried to connect and if it explode then do we know why :wink:
thank you
dogman dan   100 GW
Post by dogman dan » Feb 11 2009 8:44am
48v ping is 58 actual volts I think, so poof. :lol:
cerewa   100 W
Post by cerewa » Feb 11 2009 11:20am
If it breaks we will know why. It apparently has capacitors (and other components, maybe) that are designed for 50 volts (actual volts) max.
The ping battery is rated at "48V" but its actual voltage during use starts at about 56 volts and only drops to 48 volts when the battery is nearly 100% discharged.
I'm going to make a guess and say that there's a fairly good chance your 50 volt capacitors will tolerate 56+ volts for a little while, but not nearly long enough to serve your purposes.
liveforphysics   100 GW
Post by liveforphysics » Feb 11 2009 7:02pm
They come apart easily enough, and you can re-solder on whatever voltage rating caps you like. I would use some 75vdc caps if you want to try it at 58v, even then, its just a try. They are only 100bucks though, so it's not like you have a lot to loose just from giving it a whirl.
bobmcree   10 kW
Post by bobmcree » Feb 17 2009 3:08pm
the caps are not likely the limiting factor. take a look at the fets, and you will probably find them rated at much less than 50v. rc controllers are usually designed for low voltages, and the fets for low voltages are made with thinner layers that permit lower on resistance. A typical rc controller rated for up to 10 cells RC use is only 15v.
I do not approve of this group any longer and regret what it has become. I could once share ideas here freely that is no longer possible.
GGoodrum   100 MW
Post by GGoodrum » Feb 17 2009 3:17pm
This is one of the newer "HV"-type RC controllers, which means it is good for up to 12s LiPo setups, which is 50.4V, fresh off the charger. I have personally used CC's HV series controllers with 15s a123 setups on RC helicopters, but I haven't yet tried a 16s setup. I will this week, though. :) Don't know about these Turnigy models either. It would certainly be good to know. :mrgreen:
-- Gary
bobmcree   10 kW
Post by bobmcree » Feb 17 2009 6:37pm
GGoodrum wrote:This is one of the newer "HV"-type RC controllers, which means it is good for up to 12s LiPo setups, which is 50.4V, fresh off the charger. I have personally used CC's HV series controllers with 15s a123 setups on RC helicopters, but I haven't yet tried a 16s setup. I will this week, though. :) Don't know about these Turnigy models either. It would certainly be good to know. :mrgreen:
-- Gary
they probably use 55v fets then. 58v would really be pushing it. have fun.
