Bafang Ebrake Sensor
BonesNis   10 mW
Post by BonesNis » Mar 15 2017 9:57am
Good day
Has anyone converted the Bafang E-brake sensor to be used with a Cycle Analyst V3? It appears as though the Bafang sensor is three wire and the V3 requires two wire. Thanks for any assistance.
bafang-hydraulic-or-mechanical-brake-sensor-bbs01-bbs02-bbshd-brake-sensor-photo-1.jpg
bafang-hydraulic-or-mechanical-brake-sensor-bbs01-bbs02-bbshd-brake-sensor-photo-1.jpg (16.25 KiB) Viewed 551 times
Carbon Fat Bike - Tangent 6kw Gen 1.5 (Winter)
Carbon XC Full Suspension 29 - Tangent 6kw Gen 2.0 (Summer)
Ykick   100 GW
Re: Bafang Ebrake Sensor
Post by Ykick » Mar 15 2017 11:16am
My experience is the Bafang switches use a Hall sensor and pull up HIGH. A little under supply voltage. The CAV3 might be able to handle that signal with some minor setting changes but you would still need to send 5V supply to power them.
Myself, when I need the older switch to ground scheme to current levers I just buy magnetic reed switches, fabricate some wiring and glue a magnet to the lever.
- Frank Sinatra
