addicted2climbing
- Joined
- Aug 25, 2011
- Messages
- 212
Hello All,
I bought a Q128cst system and had it laced to a 700c wheel. I started working on the install today and ran into an issue with the PAS sensor install. The problem is I have a holotech type splined crank and bottom bracket. The PAS magnet wheel is is set up for a square drive with a gap for the PAS wheel to reside. My problem is I dont have any space betwen bottom bracket and my crank. Also the large spline woudl requre me to dremmil out the fingers on the PAS wheel to fit. I dont mind trying this, but curious if I can sandwich the PAS wheel between the crank and BB? I am sure man have had this same issue and curious how people resolved it. Also moving the PAS Setup to the drive side would not do much as I only have a single chainring so cant mount the PAS wheel to one of the ring spiders.
Here are some pics of what I have. I am open to any advice and also open to buying other items if needed to make this work on the non drive side if possible.
