Hillhater said:^^^^..if the frame has V brake mounting posts ?
Brute said:Thanks for replies everyone . What I wanted to do was upgrade the hub and electrical components to a newer better bike , preferably with disc brakes . From what I`m reading here , my hub may not be able to support a disc ?
spinningmagnets said:I have to agree with Chalo on this one. Unless you post additional info, I would default to stating that rim-brakes "at their best" are more than adequate for the rear wheel of the common ebay kits that achieve 28-MPH on flat land. I have heard that the Kool Stop pads with the "dual compound" have quite a good reputation, with a useful balance between wet-situation grip, and adequate length of life-cycle (half is soft, and half is hard, red/black)
Chalo said:Not that hub. The frame has a disc mount. The hub doesn't. Even if there's enough physical space for a disc mounting pattern, the lateral spacing will be wrong, and it's easier than you think to strip the threads of a disc adapter.
V-brakes can be stronger and more sensitive than disc brakes; they just have to be set up with some care and not composed of the cheapest possible components. I'd suggest stepping up your game with rim brakes rather than trying to impose disc brakes on a system that doesn't support them.
