front rotor
ramoge
ihave a 48v 100w made in china front wheel drive motor. i need a disc brake rotor that will bolt on to the hub. there is no name on the motor. the rim is a champion . the inside diameter is 8" there is 8 mounting places for the rotor to bolt on the hub. anyone know where i can find a rotor?
8? or 6?
If 8, I haven't seen any like that before; it might be for a different kind of brake than a disc.
If 6, you need to measure the distance from the center of the axle to the center of the holes. If it's 44mm, any ISO disc should work. If it's 48mm, you'll have to find one of the "Chinese standard" discs.
Then that is unlikely to be a bicycle disc brake mount; I don't know what it is for.
Maybe it is for mounting a tool to disassemble the hub (some of them unscrew the side cover as a whole, rather than bolting it on).
Maybe you can attach some pictures of the hub?
You might be able to have an adapter custom-made, like a "spider" for a floating-disc type.
