EZgo
1 W
I have A 2012 9C HUB MOTOR with 6 HALL WIRES & the white wire came off the little circuit board. (I THINK) This is 500 to 1000 watt 9c that Ebikekit.com uses.
Pictures attached.
I was making some wiggle room to install the thermasistor wires through the axle slot when I suddenly ended up with a white wire that was not connected to anything. I assumed it came off the hall sensor circuit board although I really did not pull on those wires. Maybe just a sub par solder job.
I looked at the solder connections on the circuit board & the wire its self with a magnifying glass & cannot see any solder on the wire nor any solder connection on the board that appears to have ever had a wire soldered to it.
I took a part an older 9c & that does not use a circuit board & has only 5 wires & white is not one of them. Most of the pictures I have looked at in endless sphere show 5 wires and the directions usually mention 5 wires as well.
Is it possible the white wire was never connected to begin with & it was stuck inside the heat wrap with the rest of the wires. Im really stumped?
Pictures attached.
