EZgo
1 W
I just posted a wire identification issue on a 9C hub motor that has been answered but I have another question about repairing a cut in the insulation of 3 wires. I thought posting a new thread would be the prudent thing to do.
In order to get 2 thermistor wires through the axle slot I removed about 10" of the black wire covering that protects the hall & phase wires. In the process of doing that I also managed to slice the insulation on 2 of the phase wires & 1 of the hall wires. So I have 2 questions:
Can I safely leave the black wire insulation off of those 9 wires leaving them bare from just before the axle slot & just outside of the axle slot? I do plan to some how cover those wires where they enter & exit the axle. WITHOUT CUTTING THE WIRES?
Can I repair the 3 insulation cuts with a dab of epoxy & A small piece of SLICED heat shrink tubing applied over the epoxy while it's still wet. WITHOUT CUTTING THE WIRES?
Look closely at the yellow & blue phase wires & you'll see the insulation glued on over the wire.
I DO NOT WANT TO CUT THE WIRES?
I run this 9c at 72 V using a lyen controller set to 39 amps. It's all managed using a V3 Cycle Analyst. It seldom gets warm let alone hot. I also added ferafluid while I had it opened up.
I attached a picture.
Thanks
EZgo
Thanks
EZgo
