Hey Guys,
I'm looking at an LCD called LCD3 that works with only certain controllers.
By this diagram photo (5 wire connector on the top):
https://ae01.alicdn.com/kf/HTB1js7J...l-Panel-LCD-Display-Electric-Bicycle-bike.jpg
you can see that you need to connect a positive, negative, ignition lock and two more mysterious wires called TX (which in that example is green) and RX (yellow).
Do you know if I can find/pull those TX and RX wires out of a regular Greentime controller or is it something that is connected to a chip that only controllers that are intended to work with the LCD3 have?
