thunderstorm80
- Joined
- Mar 29, 2016
- Messages
- 383
Hi,
Searching ES about this topic found outdated info.
Searching Google sends you to many happy shops with "Item no longer in Stock".
So I open a new thread...
I look for two Fat-bike rims:
One 80mm(+-) wide and the second 100mm(+-).
So far I only found those in Weinmann:
http://www.weinmanntek.com/Products/CHOPPER/List.htm
and the 80mm version can be bought via lunacycle:
https://lunacycle.com/weinmann-dhl80-26x4-36h-fat-bike-rim/
After getting used to Grin's complete spec, the fact that Lunacycle (or Weinmann) doens't provide the ERD looks a bit strange...
I never bought at Lunacycle and don't know if it's a reputable shop or not.
Do you know where I can get 100mm 36h rim somewhere (Google gives only outdated info and out of stock shops), and more options for 80mm rims?
If you happen to know the ERD of the 80mm rim I found it would be a bliss. (Google couldn't find it...)
Why hub-motors are still being produced in 36h pattern? This is making it harder and harder to source compatible rims. (Grin's Grinhub is the only exception I know of)
Do you think I can be fine by taking a 100mm rim 32h, and just leaving each 9th hole on the hub motor blank? It's a Fat-bike so there is MUCH less stress on the spokes, since the entire bike mass is sprung mass.
