neptronix said:
Yeah, but what's pedaling efficiency worth when it's a few MM of rubber between you and having to get off the bike and spending 5 minutes and 5-10 bucks replacing a tube? it seems to be a net negative once you consider money and time. With how often i flat, and how few miles i travel, i think that my bicycle might actually be more expensive to operate per mile than my car.
That's a big part of why I went with the Shinko MC/moped tires (and tubes) on those 20" rear wheels (smoothing out the ride was another, with no rear suspension). The only problem I have had so far appears to ahve been caused by a possible pinch due to a huge piece of metal debris (piece of car frame? dunno) I couldn't avoid on the trike, made worse by a subsequent big pothole strike, IIRC. I was afraid it might be valve stem damage (where it is bonded to the tube) but didn't seem to be the case. But I added regular bike Slime to it, and it's been fine since then (though I still need to get a pair of new tubes, just in case).
Before I did that I was having fairly frequent problems with flats, even with the tire-inside-a-tire trick. :/ (even given that the tires I was using were mostly garbage, I didn't expect that bad a problem with my previous experiences with them).
FWIW, before I fixed it with Slime, I could let the Shinko get down to 10PSI or less and it'd still roll along witout crushing the sidewalls. If I tried that on a bicycle tire it'd've probably destroyed the tire and the tube. I recall when I first installed the tires I hadn't aired them up at all yet and it still held the trike up (not with me on it) without flattening the sidewalls. The bike tires certainly weren't like that.
But there is a definite efficiency hit--it doesn't greatly affect me since I have a big battery and motors, but it's there, and does waste power and create heat I wouldn't have with the other tires--but I need the reliability more than I need the efficiency.
I'd rather pedal a bit harder and have less to worry about, but i guess no manufacturers and are thinking the same way, and consumers and bike shops aren't putting the market pressure on. The tire i am looking for just doesn't exist.
Maybe not in bicycle stuff...but if you're riding 20" bicycle wheels, there's (relatively) light moped / mc tires that would probably do it, in the 2" or 2.5" widths, 16" diameter.
Now there's a man i want to talk to. I wonder what he is using today or if he is even riding. Offroad, i can pick up 100+ goatheads in a single ride in Utah. It's insane. Slime would certainly help but it is no permanent fix.
Used to have that problem when I rode my regular bike on the canal paths years back, and is why I ended up using both slime and their protector strips--but even that didnt' stop everything, so I spent a lot of time on rides re-airing up the tires with a hand pump.
The slime did seal the holes, just that there were so MANY of them.
I tried the solid foam tubes, and they sucked; beat up the wheels in back (destroyed at least one I recall), and destroyed tires in front (actually coming off the rim in turns could happen too). I'm sure there's better ones these days, but I much prefer air in there....
Slime and stans sound like a real annoyance.. i recently bought an extra thick tube and put a sealant in it the first time.. I don't trust the idea.. i don't like the idea.. but i'm desperate now.
The armor that I used on regular bikes (and so far successfully on Yogi's trailer) is a regular tire, then another tire minus bead inside that, then a slime protector strip, then an old thick tube sliced circumferentially with valve stem removed, then a thick tube actually being used, with slime in it.
Heavier bikes, like my cargo bikes, that didn't always work on, but it was way better than anything else I'd tried.
But anything the slime wouldn't seal, I'd have to patch, and that was a huge PITA to first get teh tube out of the layers, and then to clean the slime off (had to carry a kit of stuff just to do that!), then patch it, then put it all back together and then re-air it up. :/
I'd much rather live with the rolling resistance of the tires/tubes that keep me from having to do that in the first place.
