Timberwolf
- Joined
- Oct 8, 2016
- Messages
- 3
I just realized that my English language skills are quite limited when it comes to words describing the sounds a BBS02 can make...
After about 1500 km working more ore less flawlessly my BBS02 is starting to make a "cracking" noise when i push the pedals hard when the motor is running. Pedaling with less pressure is ok. If i turn of the motor i can pedal with force without hearing the sound. With motor on everything sounds fine as long as i don't pedal (with force).
Had someone experienced the same thing and is there a known solution?
/Magnus
/Magnus
